Thread: Yeti retro fitted tow bar.
  1. Yeti retro fitted tow bar.
    Apr 2010
    staffordshire
    Sorry if this has been asked before, but I've fitted a genuine Skoda tow bar to my Dad's Yeti. I'm in the trade, so have a contact at the local Skoda dealer, so I asked them to code the vehicle for me.
    I had to fit the extra wires for the split charging, which wasn't a problem, the only query I have is that the vehicle has rear parking sensors & when reverse is selected the sensor operate with the caravan coupled, therefore they sound all the time. As I work as a Master Tech at an Audi dealer I'm aware that they switch off on Audi's, are they supposed to switch off on Skoda's?
    My contact at Skoda said the vehicle was coded via SVM, so they didn't have to code the vehicle manually, but not having done one before, they aren't sure about the parking aid issue.
    Can anyone give me a definite answer, is the parking aid switched off with a caravan coupled?
  2. Re: Yeti retro fitted tow bar.
    135 Post(s)
    2026 Post(s)
    The system is as per an 8P A3 so when the trailer is couple the stem should shut down and the ESP know as well so you need to check the long coding values in the CAN controller, PDC, ABS and I think convenience and central electrics have coding values which ODIS is not very helpful with, I feel it is taking away some of the techs skill base being too automated. VCDS would be ideal and is much more user friendly and it would not be the first time SVM missed something.
  1. What can be retro fitted?
    By M1tchy in forum Q7 - 4M Forum - 2016 -
    Last Post: 03-01-2017, 10:32 AM
  2. AMI Retro fitted but where can I put the unit
    By harj81 in forum Retrofits
    Last Post: 29-09-2015, 01:32 PM
  3. Question Can DIS be retro-fitted in an '06 A3?
    By vulpi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-09-2013, 11:01 AM
  4. retro fitted stereo
    By big jase in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-11-2010, 09:19 PM
  5. Please Help Retro fit DIS (Crusie already fitted)
    By yorkster001 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2010, 01:12 PM
