Thread: Audi A6 3.2 bank 2 misfire post engine rebuild
Results 1 to 9 of 9
Hybrid View
  1. Audi A6 3.2 bank 2 misfire post engine rebuild
    Jul 2019
    Solihull, UK
    Hi all,
    I am new to this forum. Looking for some help on a misfire my car is experiencing on bank 2.
    I have bought the car with valve related issue. After tearing the engine down and replacing damaged parts, the car now runs but with misfire in bank 2 cylinders (4,5 &6). Seems like cylinder 5 has more misfires than the others.
    I have replaced the coil pack as the connector was damaged. However, it did not solve the misfire issue.
    Here is the VCDS scan result. Noticed that the Lambda Control Bank 2 Sensor 1 is reading law range compared to bank 1.
    It would be much appreciated if you could advise on the next steps.
    Address 01: Engine Labels: 06E-910-559-BKH.LBL
    Control Module Part Number: 4F1 910 559 HW: 4F1 907 559
    Component and/or Version: 3.2l V6 FSI 0020
    Software Coding: 01050003180F0118
    Work Shop Code: WSC 02325 785 00200
    VCID: 68D863E25BE89B0141-803C
    3 Faults Found:
    16750 - Camshaft Position Sensor B Bank 1 (G300)
    P0366 - 000 - Implausible Signal
    Freeze Frame:
    Fault Status: 01010001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 165244 km
    Time Indication: 0
    Date: 2005.02.01
    Time: 14:06:06
    Freeze Frame:
    RPM: 864 /min
    Mass Air / Rev.: 114.5 mg/str
    Temperature: 54.0°C
    Idle
    Bin. Bits: 00000001
    Speed: 0.0 km/h
    18502 - Intake Manifold Tuning Valve (Bank 1)
    P2070 - 000 - Stuck Open
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 165244 km
    Time Indication: 0
    Date: 2005.02.01
    Time: 14:06:06
    16689 - Cylinder 5
    P0305 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Status: 00010001
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 221
    Mileage: 165244 km
    Time Indication: 0
    Date: 2005.02.01
    Time: 14:16:52
    Freeze Frame:
    RPM: 704 /min
    Mass Air / Rev.: 141.7 mg/str
    Temperature: 70.5°C
    Idle
    Load: 20.4 %
    Speed: 0.0 km/h
    Readiness: 0110 0001
    Thursday,04,July,2019,22:24:54:39744
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170203 DS267.2
    Ross-Tech: Home
    Address 01: Engine (4F1 910 559 )
    22:24:45 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
    26 Misfire Counter Cylinder 4
    58 Misfire Counter Cylinder 5
    1 Misfire Counter Cylinder 6
    Enabled Misfire Recognition
    22:24:45 Group 031: Lambda Control (Lambda Sensor Voltages)
    0.9961 Lambda Control Bank 1 (actual)
    0.9951 Lambda Control Bank 1 (specified)
    0.9912 Lambda Control Bank 2 (actual)
    0.9951 Lambda Control Bank 2 (specified)
    22:24:45 Group 033: Lambda Control
    -1.1 % Lambda Control Bank 1 Sensor 1
    1.968 V Sensor Voltage Bank 1 Sensor 1
    -19.5 % Lambda Control Bank 2 Sensor 1
    1.953 V Sensor Voltage Bank 2 Sensor 1
  2. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    134 Post(s)
    2018 Post(s)
    I would say your valve timing is out, what did you use to set it? The cam VVT actuators are well known for causing misfires and take care as on these, a misfire can flame and melt the cat, a surprisingly common problem on this engine
  3. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    Jul 2019
    Solihull, UK
    Thanks for your reply.
    I have used the timing kit to lock both crank and cams for correct timing.
    Your are right about the variable valve solenoid, mine came out in two pieces. Unfortunately, I have put the broken part back when reassembling the engine till I discovered it is faulty. Just fitted a replacement part so hopefully all good now.
    I will try to reset the timing of this bank.
    Many thanks
  4. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    Jul 2008
    Lisburn
    16 Post(s)
    leak down test? Cam timing 100% this would cause misfire and allow unburnt fuel through to mess up the readings.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  5. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    Jul 2019
    Solihull, UK
    I don't have the tool to do leak down test, would compression test help in this situation?
  6. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    Jul 2019
    Solihull, UK
    Quote Originally Posted by swwalker View Post
  7. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    134 Post(s)
    2018 Post(s)
    A compression test is not as informative but can show up any more obvious issues.
  8. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    Jul 2019
    Solihull, UK
    OK. I will do the test and report back here.
  9. Re: Audi A6 3.2 bank 2 misfire post engine rebuild
    May 2008
    26 Post(s)
    What are the engine block 93 readings? That will give you insight into the state of the timing. Post them up here, Bank 1 intake and exhaust, bank 2 intake and exhaust.
    You said you did an engine teardown - did you remove the intake manifold? Have you held the actuator open while reseating it so that the flap doesn’t get trapped on the wrong side of the divider in the lower manifold? Your P2070 code suggests that’s a possible issue.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  1. Question Audi V6 3.2 Bank 2 misfire post engine rebuild
    By emooo in forum 3.2l - Engine
    Last Post: 04-07-2019, 11:51 PM
  2. A3 2.0 TDI engine rebuild misfire..
    By Dave_1984 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-05-2018, 11:12 AM
  3. Please Help Misfire after rebuild
    By kaisersolsay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2011, 11:19 PM
  4. Audi 80 TDi engine rebuild
    By Overdose in forum 80 - 90
    Last Post: 12-01-2008, 12:19 AM
