Thread: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
    hi,
    Looking for some pointers on this one please
    Have a 2007 Audi A3 BKD engine. Has been fine until the other day - cranked, no start and the brake warning in instruments flashed up. After a bit of throttle it started and worked okay. Then the other day the fault re occurred but this time it was here to stay.
    • Cant communicate with the ECU but can with other modules
    • fans come on full speed almost straight away ( obviously engines cold )
    • fuse check out okay
    • swapped the relay "100" in engine compartment box for a known working unit - no change
    I haven't got a wiring diagram but assume i either have a ECU power supply issue or the ECU is faulty
    would appreciate some pointers please
  2. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
    I would even appreciate if someone had a wiring diagram for this system and I could pin it out - thanks in advance
  3. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    135 Post(s)
    2043 Post(s)
    The fans coming on show the fan controller (in the big fan) can see the what it thinks is a running engine but it cannot see a temperature signal so as a precaution it sticks the fans on at full blast. There is a command wire from the ECU to the relay which I have seen fail a number of times and the fault is buried in the harness so difficult to find, it is a stupidly thin (0.35mm CSA) and snaps. Message me your REG and email and I will send you the diagram.
  4. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
    Ok I’ve done that thanks
    what youve said makes sense but I’m always a advocate for a wiring diagram just so I can test it correctly
    the relay in the middle of the engine fuse box has a “100” on it - I assume this is the ECU relay but I’m only guessing
    I’ll wait for your email
  5. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    135 Post(s)
    2043 Post(s)
    Bear with me, I just have to change a Corrado VR6 water pump first.
  6. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    135 Post(s)
    2043 Post(s)
    Do you have the "low" as it is known engine bay electronics box with two relay positions, one with a metal bridge and one with a relay that has 100 on top and not four, is this correct?
  7. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
    yes it looks as pictured
  8. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
    ill await further instructions - ive had a read through the wiring diagram
  9. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
  10. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    Jul 2019
    Wadebridge
    So 12v at the red circles, then grounds at the top blue. The lower blue is the wire you said can break ( I know this will be 12v )
  1. Please Help Car won't start, flashing coil warning.
    By mortoney in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-10-2015, 07:45 PM
  2. 2010 Audi S5 Prestige car won't start, brake lights flashing fast
    By whitcom in forum Chat - Anything with wheels
    Last Post: 21-02-2015, 07:06 PM
  3. Replies: 19
    Last Post: 13-01-2015, 09:15 PM
  4. Powerhood warning light flashing on start up
    By jason555 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-10-2010, 08:59 AM
  5. asr abs on. brake warning flashing
    By sjcelliot in forum Golf MK4 - 1999 - 2004
    Last Post: 09-12-2008, 05:41 PM
