Thread: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
  1. Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    Mar 2017
    Coventry
    Hi All,
    Audi 2.0tfsi s line 2009 127K
    VCDS is showing following
    7207 - Cam Adjustment Actuator A; Cylinder 1 P11A1 00 [109] - Elec. Malf. or Open Circuit
    Confirmed
    as there are 2 actuators per cylinder would i be correct in assuming one is A & the other B ? to identify which is which
    therefore would the first actuator from front of engine cylinder 1 be Actuator A?
    Any assistance you guys can shed will be greatly appreciated.
    Davmar
  2. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    133 Post(s)
    1990 Post(s)
    I need you to PM me your REG or VIN to help with this.
  3. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    133 Post(s)
    1990 Post(s)
    Cylinder 1 is at the cam chain end and the part number of the thrice revised adjuster is 06H 103 697 C and not sill money at £33.23. As I am off for a week that is the most detailed information I can give you.
  4. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    Mar 2017
    Coventry
    Cheers Crasher,
    Appreciated will delve further.
    Davmar
  5. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    Mar 2017
    Coventry
    Hi All,
    Having Delved further checking resistance of Actuator coils & readings all very similar i noticed 2nd Actuator plug broken inside Actuator. Sorry cant get pictures to upload showing detail!
    Has anyone had similar issue & are replacement plugs available?
    Thanx in advance all.
    Davmar
  6. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    133 Post(s)
    1990 Post(s)
    Yes the plug will be available but I can’t look the number up until next week, they can be tricky to change without damaging the terminals and that complicates matters.
  7. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    Mar 2017
    Coventry
    Cheers Crasher,
    Sorted TPS dont do the plug Audi Main Dealer didn't have & rerouted me to Volkswagen dealer Part No V4HO 973 702 A £2.38 cheap as chips.
    Didnt come with new terminals so had to remove broken ones from damaged plug & solder to broken Terminal on end of wires, bit of a ball ache but succeeded Cleared codes in VCDS & Re scanned all GOOD
    Many thanx for your assistance.
    Davmar
  8. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    133 Post(s)
    1990 Post(s)
    They should have advised you to buy the matching repair wire.
  9. Re: Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    Mar 2017
    Coventry
    In this particular case Im glad its sorted!!!! maybe Ignorance is Bliss after all Thanx again for your input.
    Davmar
  1. Replies: 3
    Last Post: 14-06-2021, 12:28 PM
  2. Please Help 2.0tdi turbo actuator 2009 a4
    By bigred84 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2017, 11:37 PM
  3. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  4. 2009 face lift Audi S3 alloy wheel
    By blueevo9 in forum Wheels and Tyres
    Last Post: 18-08-2014, 06:03 PM
  5. Audi A6 4F pre face lift with face lift upgrades questions ...
    By gupsterg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-11-2013, 12:52 PM
