Thread: Engine speed sensor test G28
Results 1 to 10 of 11
Hybrid View
  1. Engine speed sensor test G28
    The problem I have is that the car suddenly starting losing power as I was driving on a dual carriageway at 70 mph (seriously!), I was able to continue at much reduced speed to get to safe place to stop, about a mile further on. Although just about still running the engine was making very loud clattering noises, (like it was running on). When recovered, there were initially no error codes. Initial investigations at my local garage confirmed fuel was reaching the fuel filter, but they were unable to help further.
    Towed car home, and now it has P0321 error, implausible signal, short to plus.
    I have changed the sensor with a new HAAS one, no change, then had the ECU tested by ECUTesting ltd, and this came back as no fault found. I have checked the wiring for continuity and shorts to positive and ground and all checks out as expected.
    What I am thinking to do now is test the old sensor I took out to see if it still good before I try changing it for an another new one from a different supplier.
    Or what else can I do?
    VCDS reports zero engine speed whilst cranking: (files attached) I'm pulling my hair out here.... help!
    Car is 144,000 miles (due a cambelt) A3 S-Line 2.0TDI 3dr Quattro Engine is BMN and 170bhp
    Saturday,22,June,2019,20:11:00:39744
    VCDS Version: Release 17.1.3 (x64) Running on Windows 10 x64
    Ross-Tech: Home
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Control Module Part Number: 03G 906 018 DN HW: 03G 906 018 DN
    Component and/or Version: R4 2.0l PPD1.2 1247
    Software Coding: 0000172
    Work Shop Code: WSC 00353 210 91454
    VCID: 74E0079217206FE1FD-8020
    1 Fault Found:
    000801 - Engine Speed Sensor (G28)
    P0321 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00010001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 239340 km
    Time Indication: 0
    Date: 2018.04.25
    Time: 01:30:42
    Freeze Frame:
    RPM: 224 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Time: 0.00 s
    Angle: 0.0 °
    Bin. Bits: 00000000
    Bin. Bits: 00000001
    Saturday,22,June,2019,20:13:40:39744
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170203 DS267.2
    www.Ross-Tech.com
    VIN: License Plate: KV56---
    Address 01: Engine (03G 906 018 DN)
    20:13:28 Group 001: Injection Quantity
    0 /min Engine Speed (G28)
    20.8 mg/str Injection Quantity
    6.8°KW Injection Duration (specified)
    22.0°C Coolant Temperature (G62)
    20:13:28 Group 002: Idle Speed
    0.0 % Accel. Pedal Pos. Sensor 1 (G79)
    01001000 Operation Status
    20:13:28 Group 003: Exhaust Gas Recirculation (EGR)
    223.9 mg/str Exhaust Gas Recirculat. (spec.)
    223.9 mg/str Exhaust Gas Recirculat. (actual)
    0.0 % Exhaust Gas Recirc. Duty Cycle
  2. Re: Engine speed sensor test G28
    134 Post(s)
    2019 Post(s)
    Not another BMN! Was there ever such a rare engine that gave such a disproportionate amount of trouble, since the CT? If you remember the CT you are getting old.... Which Haas part number sensor did you fit and what is the part number off of the old one?
  3. Re: Engine speed sensor test G28
    I have a second new HAAS sensor also from EuroCarParts (same as first one) with the number SN3 419440441 and G417 on it. The old one has the following: VW AG ABE Germany and PA66 GF30<
    thanks
    I also went to an Audi main dealer and asked to see an official Audi part for this sensor and he brought out a HAAS sensor too, (Didn't check the numbers tho'), but it was twice the price cf EuroCarParts.
  4. Re: Engine speed sensor test G28
    134 Post(s)
    2019 Post(s)
    There will be a 9 digit number on the VAG original either 036 906 433 B or E, the one made by AB Electronic is the E, I can’t find a way to check this with Haas as they are not on the trade cross reference system Tec Doc, which is odd if they do it, but ECP cross reference it to their number 419440441.
  5. Re: Engine speed sensor test G28
    Hi, the number on the original is 036906433E
  6. Re: Engine speed sensor test G28
    134 Post(s)
    2019 Post(s)
    Without being able to cross reference the VAG number 036 906 433 E to a Haas number I worry that you have equivalent to 036 906 433 B which puts the alignment pin in the wrong position, ETKA shows that there is no way to know which matching crankshaft oil seal holder/speed ring you have without pulling the box and flywheel.
  1. Cmp sensor engine speed sensor fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2022, 10:44 PM
  2. Question engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    By julianb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-11-2016, 07:25 AM
  3. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  4. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  5. Engine speed sensor - crankshaft sensor
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-05-2011, 09:56 AM
