Thread: overheating and other issues
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: overheating and other issues
    #11
    2025 Post(s)
    The controller is in the large fan and there are two versions 220 or 300 watt. The problem is the controller can be damaged by a faulty second fan so you must change both. The main fan is £240 from VW and the second is £205 BUT both are easily available aftermarket for much less.
  2. Re: overheating and other issues
    #12
    Jan 2019
    Thanks crasher, so not worth just changing the controller then? and how do I know which version I have of the large fan?
  3. Re: overheating and other issues
    #13
    2025 Post(s)
    The numbers are on the fans, there are two versions of small fan as well.
  4. Re: overheating and other issues
    #14
    Jan 2019
    Nothing is simple on these cars is it!
  5. Re: overheating and other issues
    #15
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Quote Originally Posted by jasst View Post
    You could say that!!
  6. Re: overheating and other issues
    #16
    Jan 2019
    Interestingly I was looking at the handbook for an entirely unrelated reason and I read the page regarding the gauges, apparently the normal operating range is up to 120degC, and the warning light will not come on till that temp is exceeded, so I may have been panicking for nothing! still seems to be a very high temp for the engine to be running at, but what do I know!
  7. Re: overheating and other issues
    #17
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Yes mine says that as well, but 120°C is definitely not normal unless you are towing a caravan up a steep hill in the hottest place on earth!
    In the UK a car should never exceed 90 maybe going up to 100 tops if you're pushing it.
  1. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  2. Please Help Fans not working and causing a number of issues (overheating/No Air Con)
    By Simon West Oz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2014, 10:08 PM
  3. S6 c5 overheating
    By w55ksy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-03-2014, 10:57 AM
  4. 1.8t Overheating
    By Lockstockfrog in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2012, 11:20 PM
  5. Overheating - Water pump issues
    By guyg in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-06-2009, 02:08 PM
