Thread: overheating and other issues
Results 1 to 10 of 17
  1. overheating and other issues
    Jan 2019
    My 2006 2.0 fsi est was overheating when stuck in traffic, I have replaced the water pump, both thermostats and both temp senders, before I did this work it struggled to get to full temp, which it now does, and runs at an indicated 90 degrees until I get stuck in traffic, when it rises to 110+ and I have to put the heater on max to bring it back down, what should I look for next?
    Also have another issue, when I did the timing belt the other day, the battery was disconnected for about 10 days, since reconnecting it will not store my average fuel consumption, and every time I switch engine off, it starts at Zero again, and there is no option 2 on the mfd to display average mpg.
  2. Re: overheating and other issues
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Have you checked that the radiator fan is cutting in when it gets to/exceeds 90 degrees? Sounds as if it isn't running which will cause it to overheat unless you put the heater on.
  3. Re: overheating and other issues
    2022 Post(s)
    If it is showing 110 on the gauge it is a LOT hotter in reality. A few days ago I was monitoring a VAG cars warm up and I got the feeling it was getting hot but the gauge said 90.... when I checked in the measuring blocks it was 108 so I turned it off. The main cooling fan, which contains the controller, had failed.
  4. Re: overheating and other issues
    Jan 2019
    When I did the thermostats I ran it up, and tried various things like air con on or off, sometimes the fans would run sometimes not, is there any way of testing the fan controller/
  5. Re: overheating and other issues
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    The fan should always run with the A/C on so don't let that fool you into thinking it is running under normal conditions. What I would do is take it for a drive then park up so as to provoke an overheat situation and see if the fan is running without the A/C on.
  6. Re: overheating and other issues
    Jan 2019
    When I tested it, sometimes the fan would not run even with the air con on.
    When it got hot in traffic again on sat I parked up and lifted the bonnet to check, and the fan was not running.
    Another thing, just been looking at new fan units on the likes of *******, have got what I think is the correct part no, but even then there seem to be different power outputs even for the same part no! (confused)
  7. Re: overheating and other issues
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Quote Originally Posted by jasst View Post
    Nothing is simple on these cars is it!
    You could say that!!
  8. Re: overheating and other issues
    Jan 2019
    Interestingly I was looking at the handbook for an entirely unrelated reason and I read the page regarding the gauges, apparently the normal operating range is up to 120degC, and the warning light will not come on till that temp is exceeded, so I may have been panicking for nothing! still seems to be a very high temp for the engine to be running at, but what do I know!
  9. Re: overheating and other issues
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Yes mine says that as well, but 120°C is definitely not normal unless you are towing a caravan up a steep hill in the hottest place on earth!
    In the UK a car should never exceed 90 maybe going up to 100 tops if you're pushing it.
  1. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  2. Please Help Fans not working and causing a number of issues (overheating/No Air Con)
    By Simon West Oz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2014, 10:08 PM
  3. S6 c5 overheating
    By w55ksy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-03-2014, 10:57 AM
  4. 1.8t Overheating
    By Lockstockfrog in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2012, 11:20 PM
  5. Overheating - Water pump issues
    By guyg in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-06-2009, 02:08 PM
