Thread: Lights Malfunction warning
Results 1 to 10 of 11
  1. Lights Malfunction warning
    Mar 2009
    York
    Wondered whether anyone can give any pointers here.
    For the past few weeks I've been putting up with a malfunction warning related to bulbs - the cold check it does at ignition.
    The car passed the MOT test yesterday as there are actually no lights that are out. I'm led to believe that the voltage check the car does means that a failing bulb can trip the warning, not necessarily a blown bulb.
    My S-Line has the Xenon headlights and LED rears, so I'm looking at all the halogen bulbs I can - front fogs, indicators, reverse lights and rear fogs.
    Anywhere obvious I can start, or that is well-known for giving the bulb warning? The local specialist said I may as well start basic troubleshooting myself to save some money...
    Failing this i know the cold check can be bypassed in VCDS (not my recommended course of action!)
    Thanks. Paul.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  2. Re: Lights Malfunction warning
    134 Post(s)
    2005 Post(s)
    VCDS will have the appropriate code stored in central electrics.
  3. Re: Lights Malfunction warning
    Mar 2009
    York
    Thanks Crasher...
    On a 14 plate (which mine is) will VCDS point to a specific bulb or simply help narrow down the issue? I’ve noticed that A6s for example tell you in the display exactly which bulb is affected, mind just gives an unhelpful warning!
    Having said that, I did prod around earlier at the bulbs I could access, and a reverse and rear fog bulb had slight blackening either side of the filament, so if the voltage reading is as picky as I’ve read, maybe they’re throwing the error reading up...
    Thanks for your help anyway, next stop a proper code read!
    Paul
  4. Re: Lights Malfunction warning
    134 Post(s)
    2005 Post(s)
    The A6 is a much more expensively engineered platform, you get what you pay for. The central electrics (AKA Onboard Supply Control Unit) of the MQB platform will detect which bulb(s) are causing it concern, a fault code reader does not do any diagnostic checks of anything, it just reads out the data stored by the cars onboard systems. The rear light unit bulb holders of the 8V are still having problems with an overloaded earth terminal which earlier models suffered from and multiple bulb codes point towards the appropriate earth.
  5. Re: Lights Malfunction warning
    Mar 2009
    York
    Would any code reader tell me the info I need (ie the plugin ones) or do you need the full vcds software? Just thinking about whether it would be worth getting one.
  6. Re: Lights Malfunction warning
    134 Post(s)
    2005 Post(s)
    You would get a decent level of info with Carista without going to the level of VCDS.
  7. Re: Lights Malfunction warning
    Mar 2009
    York
    Just to close the thread off, a local garage with vcds scanned and the diagnostics said faulty light switch. No idea why as everything works normally, must be a circuit board failing...
    Anyway found a replacement switch unit, although a year or two newer, should be an easy swap in to clear the fault.
    Thanks.
  8. Re: Lights Malfunction warning
    Mar 2009
    York
    Well, not quite the end of the thread just yet...
    I found what looked like a decent light switch, but what I assumed was a revised part, not incompatible with my car. Original 8v0941531L, new 8v0941531AR
    Fitted and turned ignition back on, sure enough a ‘bing’ and the same message appeared.
    I then (wisely I think) invested in Carista as a decent budget scanner/code reader. It also threw up a light switch fault - VAG 930056 to be precise.
    Am I now correct to assume the replacement light switch is NOT compatible? It did have a different icon for what was the front fogs - dipped and a cloud symbol - I thought that was purely cosmetic!
    There were no further error codes from anything beyond the ‘central electronics’ switch, so hopefully I can rule out any physical headlight issue.
    Thanks for helping (again!)
  9. Re: Lights Malfunction warning
    134 Post(s)
    2005 Post(s)
    8V0 941 531 L has gone to 8V0 941 532 AE with the suffix 5PR as the colour code, I cannot track down the AR from home.
  10. Re: Lights Malfunction warning
    Dec 2020
    Hi Guys,
    Please check this blog i have found maybe somebody will find it useful Audi lights malfunction - Left Right Dipped headlight warning message - Xenons4U Automotive Blogs
  1. abs esp and parking brake malfunction lights on
    By kmpa5coupe in forum VCDS - Help Requests
    Last Post: 09-03-2018, 05:56 PM
  2. Dreaded "Gearbox Malfunction" Warning
    By BigKells in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-03-2017, 08:23 PM
  3. Please Help Parking handbrake malfunction warning
    By Redcar01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-03-2014, 10:56 PM
  4. A8 Parking Brake Malfunction Warning Light
    By HIWEX in forum VCDS - Help Requests
    Last Post: 21-12-2010, 12:06 PM
  5. a6 low fuel warning malfunction
    By dieselal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-07-2007, 03:44 PM
