Thread: best dab aerial amplifier solution for android head unit in mk6 golf?
  1. best dab aerial amplifier solution for android head unit in mk6 golf?
    May 2019
    brighton uk
    hi
    i've just fitted a pumpkin android 8 head unit in my wifes mk6 2.0 golf tdi gt. it's an excellent head unit but the dab reception is a bit sketchy. i'm currently using one of the built in areals - the car didn't have a factory dab head unit before fitting the android one so i'm assuming it doesn't have a built in dab areal? - but would really like to improve the dab reception whilst using the built in areals already in the car. has anyone here found a really good solution for boosting the reception for dab using the already fitted areals which i believe are in the rear window?
    i know you can get windscreen ones, the reception i've got currently is about the same as using one of those, so i know it can be improved but don't want to fit an external areal on the car if at all possible.
    any advice appreciated.
  2. Re: best dab aerial amplifier solution for android head unit in mk6 golf?
    Nov 2018
    Tamworth
    22 Post(s)
    I've used these folks. Great service.
    In Car DAB Digital Radios > Cheap DAB for cars > dabonwheelsHome - DAB on Wheels
    In the end I didn't keep the system as the DAB reception was patchy but the help & support from the company was superb.
    Good Luck
    Andy.
  3. Re: best dab aerial amplifier solution for android head unit in mk6 golf?
    Mar 2007
    Brum
    I don’t think you can boost the existing signals to receive the DAB signal. I think VW already uses an amplifier on the aerials so you’ll need a separate DAB aerial or see if it’s possible to exchange the existing ones.
    I used an Android unit in my previous 57 plate Touran and very successfully used a stick on L shaped DAB aerial which gave as much reception as the roof mounted OEM one. I didn’t want it in the front windscreen and there wasn’t quite enough cable to reach the hatch window so I put it in the rear side window top corner. The reception will ultimately come down to how strong the signal is in your area.
    2015 VW Golf GT estate 2.0 tdi DSG
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  4. Re: best dab aerial amplifier solution for android head unit in mk6 golf?
    May 2019
    brighton uk
    thanks looks like a good site. from what the site says you can't do much with windscreen areals but i'll contact them.
  5. Re: best dab aerial amplifier solution for android head unit in mk6 golf?
    May 2019
    brighton uk
    Quote Originally Posted by AndyN01 View Post
    Good Luck
    Andy.
  6. Re: best dab aerial amplifier solution for android head unit in mk6 golf?
    May 2019
    brighton uk
    Quote Originally Posted by Scottiedogg View Post
    she gets dab currently but its not the best, i'm installing an external dab aerial on my van tomorrow so that should give me a better idea of what the dab signal strength is in my area.
  7. Re: best dab aerial amplifier solution for android head unit in mk6 golf?
    May 2019
    brighton uk
    well i installed virtually the same dab setup in my old vivaro van today but with an amplified external aerial - this one Eightwood DAB+ DAB Car Aerial DAB Antenna Splitter: Amazon.co.uk: Electronics - and the reception is amazing on both fm and dab so now i have a benchmark i can work towards and i now know it's not the local signal strength but the aerial reception in the golf that's the issue. if it was an old car i would fit one of these but don't fancy drilling holes in the golf. i've seen elsewhere that you can get a dab module for the boot which may be an option VW Golf Mk6 Mk7 Tiguan & Passat CC Retrofit DAB Aerial OEM Style Calearo 7590007 | eBay which i'm guessing you just swap out for the existing.
    but i think i'll go away and have a think befopre deciding what to do.
  1. Has anyone ever installed an android head unit replacement over concert/symphony?
    By attila_tdi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-04-2016, 06:13 AM
  2. HTC Android Phones and Premium bluetooth - solution!
    By mrchiggles in forum Golf MK6 - 2009 - 2013
    Last Post: 08-06-2011, 11:56 AM
  3. Aerial Amplifier?
    By M4YTY in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-08-2009, 12:13 PM
  4. Aerial amplifier
    By rob160 in forum In Car Entertainment
    Last Post: 23-01-2009, 12:51 PM
  5. Best ipod solution for Gamma head unit
    By stewies_minion in forum In Car Entertainment
    Last Post: 15-07-2008, 09:37 AM
