Thread: 2009 Golf Mk5 SAFE warning on dash
Results 1 to 10 of 10
  1. 2009 Golf Mk5 SAFE warning on dash
    Oct 2017
    London
    12 Post(s)
    Can anyone help with a 09 Golf 1.9 TDi with SAFE displayed on the dash?
    There is only 1 key as the 2nd is lost. The key available is not the original key, the casing is totally different (think its Audi but not sure) The car starts and drives fine. I am not sure but I believe the transponder may not have been switched when the previous owner replaced the key fob?
    VCDS give this error......
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Part No SW: 1K0 920 974 M HW: 1K0 920 974 M
    Component: IMMO VDD 2420
    Revision: V0002000 Serial number: VWX7Z0H83N28SQ
    Shop #: WSC 00000 000 00000
    VCID: 3828D8FCFE59C257321-806C
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 198246 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:32:00
  2. Re: 2009 Golf Mk5 SAFE warning on dash
    132 Post(s)
    1979 Post(s)
    Have you worked out which key is doing this?
  3. Re: 2009 Golf Mk5 SAFE warning on dash
    Oct 2017
    London
    12 Post(s)
    There only is one key, sadly the second one is lost.
    I’ve seen this before but the last time there was a second key which didn’t have the safe issue. In this case the keyfob that caused the safe problem also had the keyfob changed.
  4. Re: 2009 Golf Mk5 SAFE warning on dash
    132 Post(s)
    1979 Post(s)
    I think you may need to get a new key from VW to match the VIN and then have someone with ODIS program it in. The remote can be done with VCDS but not the immobilser chip.
  5. Re: 2009 Golf Mk5 SAFE warning on dash
    Oct 2017
    London
    12 Post(s)
    Thanks, I will give them a ring on Monday morning to see how much they want for a key and programming. Im guessing around £200?
  6. Re: 2009 Golf Mk5 SAFE warning on dash
    132 Post(s)
    1979 Post(s)
    The lower half of the key with the transponder is £92.71, if you need the upper half, a three button remote is £87.22 and I think they would charge an hours labour to program them both in so whatever their rate is for doing that job, we charge £66.
  7. Re: 2009 Golf Mk5 SAFE warning on dash
    Oct 2017
    London
    12 Post(s)
    The local dealership is charging £230 all in for key and coding so pretty much the same as your breakdown crasher. The only thing that worries me if that if after paying that whats the chances of it not resolving the issue.
  8. Re: 2009 Golf Mk5 SAFE warning on dash
    132 Post(s)
    1979 Post(s)
    There are no other options other than spending daft amounts of time and money trying to analyse the problem to probably only come to the same conclusion. With modern cars this is a dilemma I have to deal with daily, except this week when I am off finishing decorating the bathroom.
  9. Re: 2009 Golf Mk5 SAFE warning on dash
    Oct 2017
    London
    12 Post(s)
    You think? Just wait to Mrs Crasher asks for the waterfall bath taps with led lights - red for warm water and blue for cold water!
  10. Re: 2009 Golf Mk5 SAFE warning on dash
    132 Post(s)
    1979 Post(s)
    She isn’t that fussy, after all she has been married to me for 28 years so she must be forgiving or nuts..
  1. Question B8 8K 2009 A4 Advant, Dash Lights Not Coming On After Battery Changed...ONLY WITH MAIN LIGHT SWITCH
    By RAIN AGAIN in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-12-2023, 01:15 PM
  2. Chimes from Dash? B6 Passat 2009 2.0 Bluemotion
    By suley in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-12-2018, 12:15 PM
  3. Question 2009 A6 Quattro TDi dash clocks flicker
    By dean warren in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-10-2018, 04:42 PM
  4. Audi A3 Dash in Safe mode starts and die
    By Nacho Zúñiga in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-07-2015, 10:57 PM
  5. Golf not safe on road...
    By eyeballpaul in forum Golf MK5 - 2004 - 2009
    Last Post: 02-04-2008, 01:58 PM
