Thread: 2008 Vw Golf BKD 2.0 TDi Low Oil Pressure Warning
  1. 2008 Vw Golf BKD 2.0 TDi Low Oil Pressure Warning
    Oct 2017
    London
    12 Post(s)
    Just thought Id post this here as I had this issue today and a google search revealed only problems with the older engines that suffered failed oil pumps.
    When I seen this STOP Low Oil Pressure warning I assumed after reading old posts that this was the same failed oil pump issue. But after putting the oil pressure guage on the car I have approx 4 bar at idle and 7 bar at 2000rpm everything seemed fine. I switched the oil pressure sensor with an old engine and the issue has gone.
    Hope this helps someone else with the same problem.
  2. Re: 2008 Vw Golf BKD 2.0 TDi Low Oil Pressure Warning
    132 Post(s)
    1980 Post(s)
    I suggest you fit the correct 0.55>0.85 Bar switch 038 919 081 K instead of the 0.3>0.6 Bar switch from a petrol 1.4/1.6 16v you have fitted.
  3. Re: 2008 Vw Golf BKD 2.0 TDi Low Oil Pressure Warning
    Oct 2017
    London
    12 Post(s)
    Interesting, thanks for your reply. The part number I quoted was the one I removed today and the one I fitted was from a spare BKD 2.0 Tdi 2008 Golf. So Im guessing someone has changed this before and fitted the wrong one. (I edited my original post to remove the incorrect part number that was fitted in error to this engine, cheers Crasher.)
  1. golf 2.0 fsi mk 5 low oil pressure warning
    By Nigel Gill in forum Golf MK5 - 2004 - 2009
    Last Post: 01-02-2015, 06:36 PM
  2. Audi A4 1.8 (2008) 8K Low Fuel Pressure
    By Jamber1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-08-2013, 05:40 PM
  3. MK IV golf 1.4 fsi - oilcan pressure warning light
    By Sunnydec in forum Golf MK5 - 2004 - 2009
    Last Post: 13-12-2010, 05:56 PM
  4. Please Help Golf Mk4 Low Pressure warning, Already done lots of research!!
    By MagicMat in forum Golf MK4 - 1999 - 2004
    Last Post: 23-03-2010, 02:14 PM
  5. golf 20vt agu oil pressure warning issue
    By dubstar2007 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2007, 11:05 PM
