Thread: 3C rear suspension rebuild
  1. 3C rear suspension rebuild
    134 Post(s)
    2022 Post(s)
    I haven't posted anything like this before, I should show some of the interesting jobs we do. This is a 2007 Passat 2L TDI we have dropped the complete rear end out of to completely rebuild and powder coat plus de-rust and treat the rear floor. More pics over the next few days.
    All the bolts through ally and bushings were seized solid, you can't wave the oxy at ally so you have to use an induction heater
    Camber arm inner bush, some were much worse
    Inner arch rust, same both sides
    Control blade mount area rust
    Snapped damper lower lower bolt, we had to cut the damper eye open, then cut through the bush to the sleeve, heat the sleeve and get it off the broken bolt and then run the induction heater for about five minutes until the stub glowed deep red to sink heat down into the ally carrier and the bolt then wound out with no thread or ally heat damage
    With an induction wire wrapped around the subframe mounts, these boiled up and pushed out quickly
    Dropping the set up down at the blasters in the morning
  2. Re: 3C rear suspension rebuild
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Just had my rear frame off a couple of weeks ago to cut the uppers off.
    Mad Mitch
  3. Re: 3C rear suspension rebuild
    134 Post(s)
    2022 Post(s)
    When we put this back together we are fitting the later design uppers with full kits from Meyle.
  4. Re: 3C rear suspension rebuild
    Jan 2012
    10 Post(s)
    88 Post(s)
    Put Lemforder on mine which had steel Bush collars not ally.
    Should last the rest of the car life now and be adjustable still.
    Mad Mitch
  5. Re: 3C rear suspension rebuild
    134 Post(s)
    2022 Post(s)
    Yes Lemforder is good but the Meyle ones worked out better value taking into account all the bolts come with them. We coat the bolts and the inside of the sleeves with Würth ally paste.
    Some more pics
    Treated floor
    Treated rust going black
    Ohh Poo! Get the MIG out
    Treated blade mount area
    Rust after descaling
  1. How to rebuild rear Caliper Audi A4 b6
    By Rafi90 in forum Audi
    Last Post: 18-01-2019, 08:41 AM
  2. front suspension - rebuild underway - what next?
    By paulos130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-07-2011, 11:35 AM
  3. Rear Brake Caliper Rebuild
    By jammy86 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-03-2010, 06:27 PM
  4. How to strip and rebuild a rear caliper
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-09-2009, 05:11 PM
  5. Does this sound like I need a suspension rebuild?...
    Last Post: 19-08-2008, 09:21 PM
