Thread: Removing valve body / mechatronic unit from tiptronic transmission
Results 1 to 10 of 15
  1. Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Has anyone attempted this? I need to take the valve body out of my 6HP19A (KHA gearbox code) and all the YouTube videos for 6HP transmissions seem to show BMWs, which have a different system (pull the white release lever and pop the connector adapter out of the side of the transmission casing).
    I believe (but would like to verify) that on the C6, the procedure would be to drop the oil pan, remove the filter then unplug the wiring loom from the side of the mechatronic itself (ie, leave the external loom connected to the transmission casing). Then unscrew the torx 40 bolts and drop the valve body/ mechatronic.
    would be great if someone who has previously done this can confirm.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  2. Re: Removing valve body / mechatronic unit from tiptronic transmission
    135 Post(s)
    2026 Post(s)
    Drop the fluid, remove the pan, take off the filter, remove the plug from A, remove the clip from A, undo the bolts in sequence.
  3. Re: Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Awesome, thanks Crasher.
    Can i I check the meaning of a couple of those steps? “remove the plug from A” This removing the external connector and harness, ie. unplugging the signal from the ECU at the outside of the gearbox?
    “remove the clip from A” - can you elaborate on this one please? Where is the clip, what does it look like? Is it on the outside of the gearbox casing or somewhere on the inside? Does the electrical plug which sits in the side of the gearbox casing pop inwards after the clip is released? (I think there are a couple of O rings to be replaced).
    The reason I’m taking the valve body off is to renew the rubber seals (rectangular tall one and 4 cylindrical tubes). My car has the rpm fluctuations at 1400rpm in 4th, 5th and 6th (lockup clutch slip) while transmission is cold, so I’m hoping this fixes it and I can avoid replacing torque converter.
  4. Re: Removing valve body / mechatronic unit from tiptronic transmission
    135 Post(s)
    2026 Post(s)
    Yes unplug it and remove its pull through retaining clip. Do you have the equipment to refill and set the ATF level? You are asking questions that concern me as to the ability to do what is a complex task that if screwed up could write off the car.
  5. Re: Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Well I have an oil syringe pump and the ZF document which details the fill procedure. Plus vcds to monitor trans temp of course. Do I need more equipment than that?
    The bit I’m least fully clear on is the adaptation drive after deleting stored adaptation values. Do you know if this has to be run completely as written below or are interruptions to deal with traffic, turning the car around to go back down the same road, etc, ok? If you have to run it exactly as written with no interruptions at all then it must require a helluva long road with no traffic in the way!
  6. Re: Removing valve body / mechatronic unit from tiptronic transmission
    135 Post(s)
    2026 Post(s)
    I have never been able to get VCDS to do the adaptation so I use ODIS, some people seem to be able to get it to work, it depends if the pop up’s come up with the values and the drop down tables list it.
  7. Re: Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Thanks Crasher, I will check my vcds and see what it’s offering. I would also like to note down the existing gearbox adaptation values, so I’m trying to research all the necessary channel numbers and how to interpret them. Transmission channels 73-77 are the basic ones I know, but I guess there is more these transmissions can tell us, with a bit of knowledge.
    can I check - the mechatronic diagram you posted above is the correct one for KHA gearbox? It’s just the ZF info I had only shows 10 and 13 screw versions of the valve body, but your diagram has 11. Probably your info is more up to date than the below which I had. Thanks
  8. Re: Removing valve body / mechatronic unit from tiptronic transmission
    135 Post(s)
    2026 Post(s)
    That is from ELSA using your box code, remind me tomorrow and I will double check. Could you PM me the UK REG or VIN?
  9. Re: Removing valve body / mechatronic unit from tiptronic transmission
    Aug 2016
    Cape Town, South Africa
    I've cleared the clutch adaptions on VCDS a few times before. IIRC, in the transmission controller (channel 2), you go to adaptations - 10, go to channel 01, test, save.
    That should clear all the values in channels 73-77. The box might have to be above a certain temp to get it to clear, but it does work.
    Don't let anyone tell you that you can do it by holding down the pedal and switching on and off the ignition or some other story.
    2006 A6 Avant 3.0 TDi Quattro
  10. Re: Removing valve body / mechatronic unit from tiptronic transmission
    135 Post(s)
    2026 Post(s)
    Quote Originally Posted by zit501 View Post
    There are lots of old wive's tales like that. Clearing the learnt values isn't the issue, it is the basic settings to speed up the learning process, rather like performing the readiness code on an engine. It will do it itself but it takes a long time.
  1. DSG Mechatronic Electronic Control Unit Scheme Issue
    By zihniates in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-09-2018, 01:32 PM
  2. Question Does DSG Mechatronic unit replacement mean the DSG oil is changed
    By MattPassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-01-2015, 03:02 AM
  3. Searching for supplier for Mechatronic Unit
    By jononorman in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 18-09-2013, 11:14 PM
  4. Please Help mechatronic unit out of warrenty- advice needed
    By romnarz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-07-2013, 11:05 PM
  5. Question DSG Mechatronic Unit
    By danieljames in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-10-2012, 09:11 AM
