Thread: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    Feb 2007
    Hi. I did the work myself and bought a injector from PF Jones. £286 which included a £36 surcharge. You’ll need access to VCDS (Vagcom) for coding once you’ve replaced the injector.
  2. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    Jun 2021
    lincoln
    thank you so much for the quick reply!
    did the job take long? pretty sure the garages i've asked quote 4hrs ish labour.
    I've found a reconditioned Siemens injector for mine for £150/175 if the old one is returned. I've a mech friend with a VCDS/crazy computer system that can do the coding. I am unfortunately not skilled enough to change injectors and i don't think the mechs in my work would do the work on the side. So i'd have to find a garage who'd do it for me with parts provided. I've been quoted £630 for the job from a local garage.
  3. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    Feb 2007
    It probably took me 4 hrs using the tools I have at home so I’d imagine it shouldn’t take a garage more than that.
  4. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    1840 Post(s)
    Four new injectors is the usual requirement and this normally renders the car scrap at £1892.35 a set plus installation.
  5. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    Feb 2007
    It did run lumpy on idle for some time but 20k on it’s still running.
    Whilst on the subject of 1.6 TDI’s, I seem to be losing coolant with no visible leaks🤦🏻*♂️I’ve read plenty of posts about the EGR valves including from yourself Crasher so that is going to be my next job when time allows🙄
  6. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    Jun 2021
    lincoln
    i have exactly the same issue @djl78 !!
    and in regards to what crasher said. that would render my car scrap.
  7. Re: MK6 Golf 1.6 TDI CAYC Injector Leak.......but not from the usual leak off pipe!
    #17
    1840 Post(s)
    djl78, on an EA189 CRTDI, with no visible loos of coolant but it is being used, check the casting number on the back of the head
  1. Oil leak intercooler pipe?
    By bloodworm in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-01-2015, 10:08 PM
  2. 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    By white.akita in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2012, 09:46 PM
  3. Oil leak after injector replacement
    By xenon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2012, 08:22 PM
  4. Boost Pipe Oil Leak
    By BoraTDI in forum Bora - 1998 - 2005
    Last Post: 26-07-2010, 01:17 PM
  5. Please Help Turbo pipe leak?!
    By Golf_TDI in forum Chat - Anything with wheels
    Last Post: 30-09-2008, 05:38 PM
