Thread: Allroad air supension flashing yellow light
Results 1 to 10 of 11
  1. Allroad air supension flashing yellow light
    Aug 2012
    north west
    Hi, any help would be gratefully accepted.
    Having truble with my air suspension on my 2008 Allroad, its a A6 C6 4F 3.0tdi. Getting a flashing yellow suspension light and the air suspension control on the MMi is greyed out when driving. If I stop and restart the car it goes back to normal for a few miles and starts again.
    I've scanned the car and its showing:
    ------------------------------------------------------------------- Address 34: Level Control Labels: None
    Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
    Component: J197 LUFTFEDER H17 0060
    Serial number: 00619004804200
    Coding: 0000210
    Shop #: WSC 02335 785 00200
    VCID: 22419B2C860F
    1 Fault Found:
    01780 - Sensor for Vehicle Leveling
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 2
    Fault Frequency: 5
    I haven't noticed any drop in height on any corner so presumably the air suspension bags are not leaking (I think)
    Any thoughts PLEASE
  2. Re: Allroad air supension flashing yellow light
    135 Post(s)
    2037 Post(s)
    The sensor levers break off but it has not defined front or rear? There is one for each corner.
  3. Re: Allroad air supension flashing yellow light
    Aug 2012
    north west
    Thanks for the info. I'll will check them and post how it goes. This is really bugging me, there doesn't appear to be a lot of info on this problem out there but if it can be solved it may help someone else out in the future.
    Thanks again
  4. Re: Allroad air supension flashing yellow light
    Aug 2012
    north west
    Had all the wheels off and checked the linkage to the sensors but there all ok. I have sprayed the plugs with wd40 hopefully it may help.
  5. Re: Allroad air supension flashing yellow light
    Aug 2012
    north west
    Still having the same problem, can anyone please help
  6. Re: Allroad air supension flashing yellow light
    135 Post(s)
    2037 Post(s)
  7. Re: Allroad air supension flashing yellow light
    Aug 2012
    north west
    Last calibration that was done is about 8 months ago after replacing a rear air bag.
  8. Re: Allroad air supension flashing yellow light
    Feb 2016
    Strathaven, Scotland
    Don't you just hate threads that describe the exact issue you have but don't reach a solution!
  9. Re: Allroad air supension flashing yellow light
    Jan 2023
    Belfast Ireland
    Did u ever get to bottom of this issue as I’ve exact same issue
    Sean
  10. Re: Allroad air supension flashing yellow light
    Jan 2023
    Try this
    A comprehensive breakdown of how to test fix and understand air suspension
    What You Should Know About Audi Adaptive Air Suspension - YouTube
  1. rear supension creak Allroad
    By SLP V6 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-02-2025, 09:02 AM
  2. Please Help VW POLO 2005 1.2.Emodel BMD FLASHING YELLOW KEY EVERYTIME I TRY TO START ENGINE
    By jollyK in forum Polo - Derby - Lupo - Fox
    Last Post: 02-08-2018, 01:17 PM
  3. Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    By blackpenny15 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-06-2015, 08:35 PM
  4. Yellow Coil Light Flashing
    By Daff1e in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-06-2013, 09:04 AM
  5. A6 Yellow ABS Light And Flashing Red Brake Light
    By mikekirchner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-01-2008, 08:15 PM
