Thread: possible hex key failure?
  1. possible hex key failure?
    Sep 2018
    Dover, Kent
    Hi guys
    my 2.0 tdi BRE (210000 miles) recently started making a lot of noise which i suspected was the DMF, so i have replaced the clutch and flywheel but the noise is still there. I recorded a video, not sure if it'll help with the diagnosis.
    A4 B7 BRE noise from engine - YouTube
    From researching am i right in thinking this could be the start of the oil pump hex failing? The car still drives ok (although seems sluggish in 1st\2nd) and i have never had a low oil pressure warning. Any help would be greatly appreciated.
    TIA
  2. Re: possible hex key failure?
    May 2012
    Everywhere
    308 Post(s)
    Probably a given with that mileage and no previous evidence of work done in that area .
    The BRE has the double trouble of having both oil pump module being chain driven where the tensioner fails and puts the metal teeth in bits into the oil till fails and the wonderful planned obsolescence of the 77mm oil pump drive .
    I wouldn't drive it .
  1. Water Pump Failure / Cam belts failure
    By Fly100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2014, 11:36 AM
  2. Please Help Sat Nav TMC failure
    By RJAMJM in forum In Car Entertainment
    Last Post: 23-12-2011, 04:49 PM
  3. A6 2.5 TDI. ABS Failure!
    By daidub in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-11-2011, 08:50 PM
  4. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
  5. MFD failure
    By Mav2006 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-04-2008, 01:14 PM
