Thread: Thumping noise
  1. Thumping noise
    Feb 2017
    Rochester
    Audi A4 b7 tdi 140 bhp 76000 miles
    S-line
    CVT gearbox
    2007
    So I’ve got a thumping noise coming from the front end. The higher the speed the more it’s thumping. Had the tyres changed. Had the brakes changed. Had the wheel bearings checked. All ok. The sound is worse when on a long right turn. No sound at low speeds. Worse on concrete roads. No vibration through the steering wheel but I can feel vibration on the foot rest on the left. Tested all the bushes on the suspension. I’m at a lose. Could it be cv joints?
    Any ideas would be great. If anybody has had this or has any ideas.
  2. Re: Thumping noise
    Jul 2017
    Ipswich UK
    Sounds can often mislead you, so start checking away from front suspension. Check all mounts especially exhaust.
  3. Re: Thumping noise
    Feb 2017
    Rochester
    Quote Originally Posted by rainon View Post
    Ok thank you. It does sound very rhythmical. Almost like something that is unbalanced. Like a wheel unbalanced or a fly wheel. I’m not sure exactly how a cvt works in regards to how it transfers the power from the gearbox to the drive shaft. When I lifted the from and rotated the wheel forwards and backs the drive shaft did rotate about a cm.
    Do cvt gearbox’s become unbalanced?
  4. Re: Thumping noise
    May 2009
    Glasgow
    Check the undertrays and wheel arch liners
  5. Re: Thumping noise
    Feb 2017
    Rochester
    Quote Originally Posted by Roonster View Post
    Would the under trays and wheel arch liners make a rhythmical sound? Like something it unbalanced?
  6. Re: Thumping noise
    Feb 2017
    Rochester
    Turned out to be a wheel bearing in the end. Thanks for all the help. Greatly appreciated.
  1. Please Help Turbo thumping noise
    By canaryfan68 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2012, 12:28 AM
  2. Please Help Thumping noise over rough ground
    By carrascoespana in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-01-2012, 11:28 PM
  3. Question thumping noise
    By travels100 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-05-2009, 11:28 AM
  4. Thumping noise & sensation on pull away
    By Tomoski in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 12-05-2009, 02:43 PM
  5. thumping noise when turning right
    By 190sport in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2008, 04:47 PM
