Thread: Changing brake pads - Bitdi
Results 1 to 10 of 13
  1. Changing brake pads - Bitdi
    Apr 2014
    Derby
    30 Post(s)
    Quick question, what brand are the oe brake pads for a 2017 Bitdi? Light came on this morning. Are they ATE or TRW - wanting to keep oe if possible. The ATE pads are more expensive, but that is not always proof they are better.
    Supplemental question, I have changed rear pads before on my 2012 C7 A6 using VCDS to retract the parking brake. I then wound back the caliper the remaining distance required for the new pads to fit. Was this correct, whilst I had no problems, I have read you push the caliper back? Having trashed the rear calipers on a Mk2 Golf Gti pushing rather than winding, I am nervous in doing that again. What have others done, push or wind?
    cheers
    Current Fleet
    2017 Audi A6 Avant BiTdi
    2008 BMW Z4M Roadster
    2003 Clio 172 Cup
  2. Re: Changing brake pads - Bitdi
    134 Post(s)
    2014 Post(s)
    It can vary but the calipers are TRW/Girling. I can tell you in more detail if you private message me your reg number.
  3. Re: Changing brake pads - Bitdi
    134 Post(s)
    2014 Post(s)
    Yes, TRW-Girling. The genuine number is 4G0 698 451 J but daft money at £96.52, we would be fitting Pagid and discs as well. The TRW number is GDB1902 and the are fast bedding in Cotec versions which I saw demonstrated on a TRW Jolly at Der Ring test track a few years back, against their normal pads, very impressive
  4. Re: Changing brake pads - Bitdi
    Apr 2014
    Derby
    30 Post(s)
    Thanks, they are £31 on *******. Ate are £54 (rears)
    Fronts are TRW £53 and Ate £76
    Are Ate worth the extra?
    Any idea on the rear caliper - wind or push?
    Current Fleet
    2003 Clio 172 Cup
  5. Re: Changing brake pads - Bitdi
    134 Post(s)
    2014 Post(s)
    The front calipers are ATE. The rear calipers are electric wind back of the parking mechanism and then piston push back
  6. Re: Changing brake pads - Bitdi
    Apr 2014
    Derby
    30 Post(s)
    Brilliant, just what I needed, so the front calipers are Ate and rears TRW?
    I must have been lucky last time as I wound the piston back, although I am sure the piston face had a 'key' in it for a winding mechanism to fit, so very confusing.
    Current Fleet
    2003 Clio 172 Cup
  7. Re: Changing brake pads - Bitdi
    134 Post(s)
    2014 Post(s)
    Quote Originally Posted by Justinos View Post
    Yes.
  8. Re: Changing brake pads - Bitdi
    Apr 2014
    Derby
    30 Post(s)
    Have ended up ordering Ate pads for front and rear. Went through Mister Auto, but on their ebay site as cheaper, £113 delivered fror front and rear is good value for oe Ate pads.
    Current Fleet
    2003 Clio 172 Cup
  9. Re: Changing brake pads - Bitdi
    Apr 2014
    Derby
    30 Post(s)
    Did the rears at the weekend as this was what was triggering the brake pad warning light.
    I have never had rear pads wear out before the fronts before. They have lasted 45k miles as my commute is mainly A road and motorways. The fronts don't look half warn.
    I recall someone else with a Bitdi having the rears go at 10k miles - must be how the bias is set up?
    Current Fleet
    2003 Clio 172 Cup
  10. Re: Changing brake pads - Bitdi
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    That is strange, the front end should always bare the brunt of the braking force otherwise the rears would always lock up. Odd.
  1. Question Changing Rear Brake Pads with Electronic Parking Brake
    By Mikeinho in forum Golf MK7 - 2013 - 2019
    Last Post: 24-08-2019, 03:10 PM
  2. changing from brake pads
    By passatmick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-06-2010, 09:24 AM
  3. Changing Brake Pads
    By jimbo73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2008, 09:38 PM
  4. Changing brake pads
    By philc. in forum Audi A3 - Archive Topics
    Last Post: 30-04-2008, 09:38 PM
  5. Changing Brake Pads
    By super_dudes in forum Polo - Derby - Lupo - Fox
    Last Post: 14-02-2008, 07:18 PM
