Thread: 2008 Caddy Maxi Starting issue
  1. 2008 Caddy Maxi Starting issue
    Cornwall
    Hi all,
    I've recently acquired a '58 Caddy Maxi Life and have been slowly working through its issues. The latest one to happen, is a totally unresponsive starter only a couple of hours after I had stopped the car. I went back to it a few hours later again and it started without hesitation.
    I have previously noticed a hesitation when starting warm, this may be unrelated.
    Fault codes for terminal 30 and cam sensor have been persistent, as was the ignition switch. The ignition switch has since been replaced and the fault code has disappeared (newer scan)
    The cambelt has just been replaced and this sensor fault may well stay clear if the belt was stretched, but not sure about that one.
    Other than starting or not, as the case may be, there appears to be no other issue, even the wipers work as they should, although the fault code for terminal 30 appears to indicate a fault with them.
    Scan below.
    Code:
    Thursday,02,May,2019,16:59:59:38737VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.1.0 (x64)
    Data version: 20190114 DS296.0
    www.Ross-Tech.com
    VIN: WV2ZZZ2KZ9X030324   License Plate:
    Mileage: 182160km-113188mi   Repair Order: Pre mods
    Chassis Type: 2K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
    VIN: WV2ZZZ2KZ9X030324   Mileage: 182160km-113188miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
       Component: R4 1,9L EDC  000SG  2387
       Revision: --H08---    Serial number: VWX7Z0H53NR1C7
       Coding: 0000071
       Shop #: WSC 35110 377 00162
       VCID: 70E5EC60633442CA2D-8024
    1 Fault Found:
    012295 - Camshaft Position Sensor (G40)
                   P3007 - 000 - No Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 3
                        Fault Frequency: 82
                        Reset counter: 255
                        Mileage: 181814 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:00:31
                 Freeze Frame:
                        RPM: 1428 /min
                        Speed: 47.0 km/h
                        Load: 0.0 %
                        Voltage: 14.44 V
                        Bin. Bits: 00000000
                        Idle Stabilization: -3.9°KW
                        (no units): 48.0
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0020801
       VCID: 76E9DA7801506CFAF7-8022
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 01000008687319
       Coding: 01884F030004100057000000000000000008FF075C000120000000000000
       Shop #: WSC 35110 377 08192
       VCID: 336F236C52A239D210-8066
       Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 200608 021  0501
       Coding: 00038805
       Shop #: WSC 35110
    2 Faults Found:
    00978 - Lamp for Low Beam; Left (M29)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 181816 km
                        Time Indication: 0
                 Freeze Frame:
                            ON
                        Voltage: 5.00 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00926 - Terminal 30
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 19
                        Mileage: 181807 km
                        Time Indication: 0
                 Freeze Frame:
                            ON
                        Voltage: 5.00 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AJ    HW: 6Q0 909 605 AJ
       Component: 1C AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037UR00GASZ
       Coding: 0012611
       VCID: 7F073F5C2E6A2DB2A4-802A
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 BT    HW: 1K0 953 549 BT
       Component: J0527           752 0101
       Coding: 0000002
       VCID: 050BADB44CB67762EE-8050
    5 Faults Found:
    00576 - Terminal 15
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
    Address 17: Instruments        Labels: None
       Part No SW: 1T0 920 954 C    HW: 1T0 920 954 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0H53NR1C7
       Coding: 0016401
       Shop #: WSC 80093 222 69422
       VCID: 356B1D745CD627E23E-8060
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 040708F2001496
       Coding: 89801F060002027401
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO            VDD 1222
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
       Part No SW: 1T0 959 701 H    HW: 1T0 959 701 H
       Component: Tuer-SG         006 1206
       Coding: 0000532
       VCID: 3C7D08507FFCF6AAC1-8068
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Component:    KSG              0401
       Coding: 818B04087F2D8405485AC61010C0
       VCID: 0005BCA05394524ADD-8054
       Subsystem 5 - Part No: 2K0 951 172
       Component: Innenraumueberw.009 4807
       Coding: 00000000
       Shop #: WSC 00000
       Subsystem 6 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 7 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Component: Tuer-SG         005 0929
       Coding: 0000532
       VCID: 3973114470CEC382DA-806C
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  013 0036
       Revision: 00000000    Serial number: VWZ1Z2I6675681
       Coding: 0100040004
       Shop #: WSC 01357 011 00200
       VCID: 65CB8D346CF697624E-8030
    3 Faults Found:
    00856 - Radio Antenna
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 19
                        Mileage: 182165 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 00:00:09
    00821 - Antenna 2 for Radio (R93)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 19
                        Mileage: 182165 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 00:00:09
    01044 - Control Module Incorrectly Coded
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 19
                        Mileage: 182165 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 16:59:03
    End-------------------------(Elapsed Time: 01:25)-------------------------
  2. Re: 2008 Caddy Maxi Starting issue
    Cornwall
    Terminal 30 fault in Central Electrics now cleared - fuse in wrong position.
    Now looking at cam position sensor. Have 5v at two plug pins to sensor and a ground, but there are 10ohms on the ground. Is this normal?
    Where does the ground connect to?
  3. Re: 2008 Caddy Maxi Starting issue
    Cornwall
    Camshaft sensor replaced.
    Fault changed from "no signal - intermittent" to "no signal" hard fault. Old sensor refitted and fault back to intermittent.
  4. Re: 2008 Caddy Maxi Starting issue
    Cornwall
    Car failed to start again, a tap on the solenoid brought it back to life. The starter was change and it did feel a bit rough, so crossed fingers that it's resolved.
    Still would like the wiring for the cam sensor though, that's bound to reappear.
  1. caddy maxi 1.9tdi 2009 bls engine
    By Armandosaliu in forum The Commercial Range
    Last Post: 04-06-2013, 09:17 PM
  2. Advice on buying a 2008 Caddy Maxi?
    By The Dude in forum The Commercial Range
    Last Post: 27-02-2010, 01:48 AM
  3. 2008 vw caddy maxi
    By Mini Mark in forum Chat - Anything with wheels
    Last Post: 29-05-2009, 01:38 PM
  4. Caddy Maxi Van - when will it have Touran front end ?
    By pollensa in forum The Commercial Range
    Last Post: 18-07-2008, 10:01 PM
  5. Volkswagen Unveils The New Caddy Maxi
    Last Post: 29-10-2007, 08:45 PM
