Thread: VW golf 2.0 tdi BMM
  1. VW golf 2.0 tdi BMM
    May 2019
    Stranraer
    I am having a problem with my Golf 2.0 Tdi BMM engine. The car runs great about town and on short runs about 20 to 30 miles. But when I go a journey of over 50 miles the car starts running rough like it's missing when you accelerate . It's ok when you stay at a steady speed . This has happend about 6 times . On 2 occasions my wife was driving and she made 2 stops after her 75 mile journey for shopping and on both occasions at the second stop the car would not start . She came back to the car after 45 mins it would start again just before the breakdown recovery turned up. He recommended changing the fuel filter, Which I did but no difference . The second time recovery came the guy recommended changing the injector cable in the head which I did but still the same . Has any one had the same problem or anyone recommend what else to try as this needs to get fixed . I have vagcom the car with no faults showing up . Help!!.
    Last edited by Smokey55555; 09-05-2019 at 06:32 PM. Reason: Forgot more information
  2. Re: VW golf 2.0 tdi BMM
    131 Post(s)
    1976 Post(s)
    Has it had the DPF removed?
  3. Re: VW golf 2.0 tdi BMM
    May 2019
    Stranraer
    It has no pdf fitted
  4. Re: VW golf 2.0 tdi BMM
    131 Post(s)
    1976 Post(s)
    Sorry I can't help you with this unless the DPF is refitted and the ECU re-flashed back to standard, I have lost count of the number of BMM and BMN engines that run badly with the DPF illegally removed.
  5. Re: VW golf 2.0 tdi BMM
    May 2019
    Stranraer
    The car was not fitted with a dpf from the factory
  6. Re: VW golf 2.0 tdi BMM
    131 Post(s)
    1976 Post(s)
    All BMM’s are factory DPF, those without are BKD.. Private message me your REG and I can show you.
  1. Replies: 0
    Last Post: 11-03-2016, 01:40 PM
  2. Replies: 1
    Last Post: 17-12-2015, 06:14 PM
  3. Replies: 0
    Last Post: 11-09-2015, 04:08 PM
