Thread: Uberlame TSB list not working....can anyone help!
Results 1 to 10 of 13
  1. Uberlame TSB list not working....can anyone help!
    Dec 2018
    North Wales
    Hi folks, done a bit more on Project Panzer, it even got a cut and polish the other day, very sparkly.
    Anyhow one of the last jobs on the mechanical list is to fix up the fuel gauge which when plugged into VCDS told me it was the fuel sender issue so I've got the Audi repair kit and have tried hard to find a copy of the TSB related to removal of the sender and splicing the new wires into place.
    However the Uberlame site that had all the TSB's listed is no longer available (404) and I'm struggling to find a copy of the relevant document.
    Can someone in the know give me a steer in the correct direction.
    I can't believe that it isn't available somewhere on the net but I'm stuffed if I can find it.
    Please help before I run out of fuel!
  2. Re: Uberlame TSB list not working....can anyone help!
    Jul 2008
    Lisburn
    16 Post(s)
    there's a repair kit?!?!? do share the Part #.
    Something is jogging my memory on a TSB on the fuel sender, ill have a dig and see what i have.
    ill see if i can dig it out and post share it. can they be found in erwin - necer got round to looking for them.
    Stewart
    1986 coupe quattro (kv)
  3. Re: Uberlame TSB list not working....can anyone help!
    Jul 2008
    Lisburn
    16 Post(s)
    must have it some where - but cant find it was looking for a PDF but this post suggest i cut and paste into word to tidy up
    000438 improper fuel reading
    ill look again
    edit :- found it its only checking - now shared via google drive
    https://drive.google.com/open?id=10w..._a9nNYet4uCgcl
    if you have the TSB number throw it this way ill see what i can come up with
    Stewart
  4. Re: Uberlame TSB list not working....can anyone help!
    Jul 2008
    Lisburn
    16 Post(s)
    was buggin me that and i just cant get into the flow in work so i found this tsb
    Fuel Pressure Sensor (2).pdf - Google Drive
    dont thinkits the one you are after - do you have the dead link?
    Stewart
  5. Re: Uberlame TSB list not working....can anyone help!
    Dec 2018
    North Wales
    Thanks for the help, indeed it seems the TSB you have kindly shared is a sender check rather than the fix.
    Part number is 4F0 298 200 B which is listed as a repair kit and contains some wires, some plugs and a few scotch lock connectors. I'm kicking myself now as I'm sure I found the repair procedure somewhere but didn't bookmark it....what a clutz!!
    I have found a list of TSB's on another forum and it's these two that I need from memory.
    Fuel gauge does not go to Full after filling up
    Fuel gauge reads empty after refueling
  6. Re: Uberlame TSB list not working....can anyone help!
    Jul 2008
    Lisburn
    16 Post(s)
    Fuel gauge reads empty after refueling.pdf - Google Drive
    Fuel gauge does not go to Full after filling up.pdf - Google Drive
    so one is a software fix and the other an 18 pager...
    good luck - i am off to find that repair kit
    Stewart
  7. Re: Uberlame TSB list not working....can anyone help!
    Dec 2012
    Aylesbury
    I carried this out on mine a year or two ago with that kit. It’s not a pleasant job to say the least, and you’ll need new seals at a minimum and possibly the rings too. Have a lot of industrial tissue around, it’s messy.
    Basically all this does is replace the push lock black connectors with a scotch block type fitting. So as long as you get them replaced and actually manage to squeeze it all back in then you’re good. Start on the passenger side, it’s easier.
    2017 Audi S4 Navarra Blue
  8. Re: Uberlame TSB list not working....can anyone help!
    Dec 2018
    North Wales
    What am I doing on the passenger side, is that side just a blank?
  9. Re: Uberlame TSB list not working....can anyone help!
    Jul 2008
    Lisburn
    16 Post(s)
    i am no tthe only one then . Yeah the tinterweb shows a pump each side but mine only has one on the right
    Stewart
  10. Re: Uberlame TSB list not working....can anyone help!
    Dec 2012
    Aylesbury
    There’s two sides for the Quattro version of the fuel tank. The passenger side has a kind of tube that sucks the fuel over the middle tunnel to the driver side where the pump is located.
  1. Replies: 6
    Last Post: 20-11-2018, 02:52 PM
  2. List of errors from TDI
    By Jaymie1989 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-08-2017, 11:03 AM
  3. What should be on my 'must have' list
    By beanwood in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-04-2011, 11:27 AM
  4. Specification List?
    By Jamiem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-03-2010, 12:10 AM
  5. My 04 1.8T option list...
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-06-2008, 09:41 AM
