Thread: P242C Exhaust Gas Temperature Sensor B1 S3
  1. P242C Exhaust Gas Temperature Sensor B1 S3
    Jul 2016
    Glasgow
    Hi guys.
    I need some help.
    I have a 2014 64 plate Volkswagen passat B7.
    I have Engine management lamp light flashing for past few days now. I have managed to scan via VCDS and get the following code -
    1 Fault Found:
    14358 - Exhaust Gas Temperature Sensor; B1 S3
    P242C 00 [167] - Short to Ground
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 169942 km
    Date: 2055.14.18
    Time: 13:24:39
    Engine speed: 1384.75 /min
    Normed load value: 0.0 %
    Vehicle speed: 50 km/h
    Coolant temperature: 92 °C
    Intake air temperature: 20 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.101 V
    Unlearning counter according OBD: 40
    Exh.gas temp.sen 3-TEG_MES[1]: -169.46 °C
    Sensor for engine block temperature: raw value-Coolant temperature: 92 °C
    Exh.gas temp.sen 1-TEG_MES[0]: 249.60 °C
    Exh.gas temp.sen 4-TEG_MES[2]: 198.54 °C
    Readiness: 0 0 0 0 0
    I am wanting to know where the location of that B1 S3 is? When i tried to call VW parts and TPS parts, both asked me what is the colour the connector for that sensor.
    I have went to three different garages and they all said the sensor should be behind the engine at the top. Please help me.
  2. Re: P242C Exhaust Gas Temperature Sensor B1 S3
    131 Post(s)
    1974 Post(s)
    B1 is bank one and the engine has only one bank. S3 is the second sensor, it has three, S1, S3 and S4, yes I know.....
    S3 is the one on the DPF, to give you the part number I need your REG number.
  3. Re: P242C Exhaust Gas Temperature Sensor B1 S3
    Jul 2016
    Glasgow
    thanks for your reply, so the fault i have is from one of the sensors in the engine bay? My registration is SF64WYG
  4. Re: P242C Exhaust Gas Temperature Sensor B1 S3
    131 Post(s)
    1974 Post(s)
    I get that as 036 906 088 J but I want to check it at work on Tuesday.
  1. P246e bank 1 exhaust gas temperature sensor 4
    By Dorra69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2023, 12:01 PM
  2. Replies: 4
    Last Post: 04-06-2020, 01:10 PM
  3. Question Exhaust Gas Temperature Sensor Bank 1 Sensor 1 fault -> more noise?
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2018, 12:32 AM
  4. EML on. Which exhaust gas temperature sensor ? Please Help
    By Radders567 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-09-2012, 04:34 PM
  5. Exhaust Gas Temperature Sensor fault
    By looney in forum VCDS - Help Requests
    Last Post: 20-06-2012, 09:03 PM
