Thread: Air level sensors
  1. Air level sensors
    May 2019
    Cambs
    Hi All,
    After some advice as struggling to get car into a local vag specialist
    Audi Q7 required 2 front level sensors due to one failing and snapping in half. Soon after driving away from garage suspension light come on and said not available to lower/higher car. Unfortunately I would of taken car back but this happened while on holiday in France so chose to ring garage and they apologised and explained they had forgotten to reset codes.
    Back in the uk I realised one side of the car seems higher than the other and measured approx 20mm higher on the left.
    Turning off and on car allows you to lower higher until you drive for a few miles then it faults and raises suspension to auto.
    I haven’t been able to get codes but have read a calibration of suspension height which may be the reason for the code?
    Has anyone ever seen this before, I’m based near cambridge if anyone is local
  2. Re: Air level sensors
    131 Post(s)
    1978 Post(s)
    Sounds like the system needs calibrating.
  3. Re: Air level sensors
    May 2019
    Cambs
    Managed to get car into garage and they have said all suspension needs resetting which takes 3 hours and then it may need further fine tuning. Does this sound right?
  4. Re: Air level sensors
    131 Post(s)
    1978 Post(s)
    Complete male bovine faeces....
  5. Re: Air level sensors
    May 2019
    Cambs
    Car back now looks level and no codes but it’s sitting really high! Put suspension mode into auto and measured rear suspension height from centre of cap to bottom of arch and it’s measuring 520mm. Looks ridiculous. Putting it into dynamic hardly changes anything and it’s still sky high! Am I right in thinking back should be 465mm?
  6. Re: Air level sensors
    131 Post(s)
    1978 Post(s)
    It has been incorrectly indexed, the value they have entered for the measured height is too high.
  1. Replies: 8
    Last Post: 24-04-2014, 07:04 AM
  2. Low Oil Level Warning Light on but level OK - Anything else to check
    By new2vwa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-10-2013, 07:03 PM
  3. Oil level warning light on BUT oil level is correct!
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-08-2011, 07:44 PM
  4. Tdi 140 oil level
    By p1lts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-08-2010, 11:10 AM
  5. Oil level...
    By Chuckles in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-04-2010, 08:33 AM
