Thread: 2005 VW Transporter T30 Camper leisure battery location
Results 1 to 10 of 13
  1. 2005 VW Transporter T30 Camper leisure battery location
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Hi all,
    Just wondering if anybody could advise me where the leisure battery is located in the above vehicle, which is kitted out to be a camper van.
    I would like to be able to check the connections and the voltage to make sure it is still in good order before any load was put on it, but I can't seem to find where it is. The person who sold it a couple of years ago said it was located under the driver's seat, but if that's the case then I can't find a way to lift/remove it, unless it actually needs to be unbolted from the floor to access? That seems like an awful place to put the battery if it is but being a VW it wouldn't surprise me!!
    Any help would be appreciated.
    Thanks.
  2. Re: 2005 VW Transporter T30 Camper leisure battery location
    Jul 2018
    Liss UK
    There are a few places it could be - in the engine compartment, under the driver's seat or under the passenger seat.
    Mine is under the passenger seat but if he previous owner said it is under the driver's seat that seems to be the most likely location.
    You should be able to see it by moving the driver's seat fully forward. To take the seat out its only a few bolts - less than five minutes to do.
    You can check the voltage at any socket served by the leisure battery without removing the seat. More importantly you need to know where the fuses have been placed for the split charge and feeds from the leisure battery. Hopefully it has been done properly.
  3. Re: 2005 VW Transporter T30 Camper leisure battery location
    Mar 2016
    Minervois, France
    54 Post(s)
    I find the British way of describing sides of vehicles relative to driver, or nearside and offside, as very confusing for people driving on the other side.
    My T25,which is LHD, is nothing like a T30, but the leisure battery, is under the Left hand (driver's) seat and the start battery is under the Right hand (passenger's) seat.
    However, a steel plate with a centre post had been bolted over the well below the RH seat, with a turntable carrying the seat runners rotating above it, to enable the seat to swivel to face the back of the van.
    I removed the contraption for access to the battery and never replaced it.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: 2005 VW Transporter T30 Camper leisure battery location
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Quote Originally Posted by mbeenham View Post
    Thanks I'll move the seat all the way forward and see.
    Am I right in saying though that the sockets should be providing 230-240 volts when the inverter is turned on otherwise I don't know how to test the voltage (I.E that it is at least 12.7 and therefore still healthy).
    It should all be wired up correctly as the van was converted and then rented out by a local camper van company before being sold.
  5. Re: 2005 VW Transporter T30 Camper leisure battery location
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    How long to leisure batteries normally last? I don't know when this one was last changed and it hasn't been under any load whatsoever for at least 2 years so may it be worth replacing anyway?
  6. Re: 2005 VW Transporter T30 Camper leisure battery location
    Jul 2018
    Liss UK
    The best way to tell is to use it and see how much charge it is holding. When it is no longer able to hold a useful charge it needs replacing.
    How long it will last depends on so many things but mainly how well it is recharged after a deep discharge. That will depend to a large extent on the type of charger you have.
    Modern smart chargers can extend the life of a battery considerably. There is a lot of literature on the subject which a web search will reveal. If this battery has been standing idle for 2 years without being charged it may not have a lot of its original capacity left.
  7. Re: 2005 VW Transporter T30 Camper leisure battery location
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    I was under the impression that when not being used it would still get a charge from the alternator when the engine is running? If that isn't the case then it probably is toast by now.
  8. Re: 2005 VW Transporter T30 Camper leisure battery location
    Jul 2018
    Liss UK
    If the engine has been run on a regular basis and the split charge is working then it may be OK.
    Try it out and see how well it performs.
    There are a lot of unknowns here!
    If it is a 100Ah battery then that's 10 amp for 10 hours. At 12v that's 120W
    If running a load via an inverter say 100W to allow for losses.
    This is the maximum, you should be happy with 75% of that.
  9. Re: 2005 VW Transporter T30 Camper leisure battery location
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    OK, thanks! Last question, presumably I can test the split charging by running the engine and testing the leisure battery voltage which when charging should be 13-14 volts?
  10. Re: 2005 VW Transporter T30 Camper leisure battery location
    Jul 2018
    Liss UK
    That's correct, normal voltage out of the alternator is 14.4 volts but they can vary a bit.
    15v then you've alternator problems.
    Happy camping, may your lights never go out...
  1. Leisure Battery Load
    By shedman in forum The Commercial Range
    Last Post: 31-01-2011, 12:03 PM
  2. Question 1971 Volkswagon Transporter Camper
    By Cabbage Camper in forum The Classic VW's
    Last Post: 15-06-2010, 12:05 AM
  3. Leisure Battery and radio reception
    By Tiny Wee Allan in forum The Commercial Range
    Last Post: 06-06-2010, 06:01 PM
  4. T5, alternator D+, leisure battery
    By teote in forum The Commercial Range
    Last Post: 13-05-2009, 02:36 PM
  5. Problems with VW Transporter Camper
    By eric_peterhead in forum The Classic VW's
    Last Post: 19-03-2008, 04:42 PM
