Thread: Jacking up for an oil change
Results 1 to 10 of 10
  1. Jacking up for an oil change
    Liverpool
    11 Post(s)
    have always had the Audi serviced locally, but going to change the oil and filters myself. Wheres best to jack the A4 cab from? (I'm assuming it needs to be level for all the oil to drain out?)
  2. Re: Jacking up for an oil change
    Jan 2009
    Birmingham
    36 Post(s)
    i've been servicing my car since i bought in it 2008 and always suck the oil out the dipstick using a pella pump
    Pela 6000 Oil Pump - Oil Extractor/Oil Extraction Kit. Oil Change Sump Pump! 6 litre: Amazon.co.uk: DIY & Tools
  3. Re: Jacking up for an oil change
    Sep 2008
    6 Post(s)
    You can jack from either side of the car. There should be indents on the sill for jacking points. Get yourself a jack pad. It saves crushing the sill, and combined with a 2 tonne trolley jack is a doddle. Obviously, whack in an axle stand for good measure, and chock rear wheels. There's an engine undertray to come off first. I can't remember if the sump plug has an integral washer, but get a copper one as a precaution.
    2016 BMW i3 REx (80k)
  4. Re: Jacking up for an oil change
    Jul 2007
    somerset
    8 Post(s)
    The washer is part of the new sump plug. When I do my oil changes I am lucky in a way as my driveway has a slight slope so I drive up onto breeze blocks (with varying heights of wood first) and this lets me gain good access to the under tray and sump plug and also still gives me access from above to remove the coolant tank to one side and remove the filter. The car is almost spot on level. I do remove the under tray first and then take the car for a good run to get the oil good and hot and super runny before draining. Do this every 6 months.
  5. Re: Jacking up for an oil change
    Liverpool
    11 Post(s)
    Thanks spartacus
    Any recommendation for the jacking pad or a link to one please?
  6. Re: Jacking up for an oil change
    Sep 2008
    6 Post(s)
    This is what I use. The pinch seam on Audi and Skoda is quite deep, so a deep slot works well. Vehicle Pinch seam Weld Deep Trolley Jack Tool Rubber pad block Classic jack pad | eBayyg
    The jack pad is reinforced, make in Slovakia., etc.
  7. Re: Jacking up for an oil change
    Feb 2009
    Just be careful, sump is Aluminium so don't over-torque the sump plug - 30NM according to Elsawin - I did once and was then not able to take the plug out so had to use a pump until the sump cracked and had to get a new one.
    W.
  8. Re: Jacking up for an oil change
    Mar 2018
    Dublin
    I did this last week, I simply drove two wheels (passenger side) onto a kerb so that the car was tilted towards the sump plug to ensure all oil came out. Put car in gear and handbrake on ahrd before getting under and make sure wheels fully on footpath. As mentioned above go for drive first to warm oil and remove coolant tank (1 screw and a cable) to get good access to filter from above.
    I'd be careful with using breeze blocks (that are the ones with holes, yes?) in case they break - bricks are actually not very strong in some directions.
  9. Re: Jacking up for an oil change
    May 2008
    Newbury
    Another vote for just sucking it out the the dipstick hole, turn the job into a 10 minute simple task, especially on the 1.9tdi I had as the filter comes out the top as well. Quick, simple, no jacking and no mess (or even risk of it). That said, don't know which engine you have so the filter may be a little more tricky to get at from the top than mine was. I used to run mine on long life servicing but do an intermediate oil/filter change myself at 10k miles to avoid the camshaft lobe issue, which given I sold it with 240k miles with no symptoms seems to have paid off!
  10. Re: Jacking up for an oil change
    May 2012
    Everywhere
    308 Post(s)
  1. Question Jacking up my A4
    By philingle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2016, 10:27 AM
  2. Jacking points and jacking stand location
    By fm_carv in forum Passat - B8 Forum - 2015 -
    Last Post: 02-04-2016, 12:54 PM
  3. 9n jacking
    By DOILY in forum Polo - Derby - Lupo - Fox
    Last Post: 14-07-2010, 02:52 PM
  4. Jacking up for oil change
    By MFTM in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-07-2009, 05:11 PM
  5. jacking
    By lawrend in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 02:24 PM
