Thread: Fuel filter replacement
Results 1 to 10 of 11
  1. Fuel filter replacement
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Do you need VCDS to prime the fuel system? Does it not self prime when you start the engine?
    57 A6 2.0 tdi 140 SE. Standard except for MMI Basic + and a remap by Expert Tuning, and a want list as long as the equator!
  2. Fuel filter replacement
    Aug 2013
    Dalry - Ayrshire-Scotland
    30 Post(s)
    Good query; I too am interested in the Answer. I am due a fuel filter change and want to do it myself. Have purchased a Mann Fuel filter... and I am familiar with the filter location and access arrangements. Is it a straightforward swap over and turn over engine to start...etc? .... 2.0 TDi C7 etc.
    A6 Black Edition - 2014 - 2.0 TDI Manual
    Daytona Grey Pearl, Full LED Headlights, Technology Pack, Advanced Key
    4 Zone Climate Control & Heated Seats, Colour DIS, Lighting Pack - LED Ambient Lighting.
  3. Re: Fuel filter replacement
    Jun 2016
    NSW Australia
    I have used my odbeleven to run the pump to prime the system. Didn't want to run the risk.
    You could try just cycling the ignition untill your satisfied it's primed.
    Sent from my SM-N960F using Tapatalk
  4. Re: Fuel filter replacement
    May 2014
    Darlington
    78 Post(s)
    If you go by the manual you should prime the system, however Audi dealers never bother and just turn the engine over.
  5. Re: Fuel filter replacement
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Cycling the ignition does nothing on the CR engines.
    The pumps only run when cranking the engine & when running.
    So either make sure you fill the filter fully then crank ( risk damage to the HPFP ) or use VCDS to prime it. ( Best option )
  6. Re: Fuel filter replacement
    Aug 2013
    30 Post(s)
    Not really wanting to take any risks with this. I have obdeleven.... Is the ‘run fuel pump/prime’ function fairly straightforward/easy to find/use?
  7. Re: Fuel filter replacement
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Quote Originally Posted by Gmonster View Post
    From memory go to
    CONTROL UNITS
    ENGINE
    FUEL SYSTEM
    FUEL PUMP
    You then have option to prime the pump, you'll hear the air as the system purges. I did the prime function twice just to be sure, it runs the pump for between 1 and 2 mins.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  8. Re: Fuel filter replacement
    Aug 2013
    30 Post(s)
    Cheers will have a look.
  9. Re: Fuel filter replacement
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    When I did mine on the 3.0V6, I started the engine, and it ran perfectly with no missfires or stumbles.
    So the pump appears to be able to cope with an air filter's worth of air, fire it back down the return, and not get any in the high pressure circuit.
    The must be a chamber that the HP pump draws from the bottom, the air rises to the top and exits via the return line.
  10. Re: Fuel filter replacement
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I agree with bluezie. I have changed the filter 3 times and no problems
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  1. Air Leak in Diesel fuel line after Fuel Filter Replacement
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2015, 09:55 AM
  2. A4 3.0 Tdi Quattro Fuel Filter replacement. !!
    By razor37 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-01-2014, 03:26 AM
  3. Fuel filter replacement
    By bloostar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-04-2013, 06:56 PM
  4. Fuel Filter Replacement
    By MacHighlander in forum Golf MK6 - 2009 - 2013
    Last Post: 21-03-2012, 06:12 PM
  5. Question fuel filter replacement
    By soulstyler in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2010, 06:32 PM
