Thread: “Headlight Range Control Defective” after headlight removal
  1. “Headlight Range Control Defective” after headlight removal
    Jul 2012
    United Kingdom
    Today I did some work on the power steering fluid reservoir on my 2010 A4 B8. To get at it I removed the passenger headlight and unplugged the cable from the left-hand side of the unit marked “ESP”. I reconnected that cable prior to starting the engine, but had to run it with the passenger headlight disconnected.
    When I put it back together, I’m now getting a “Headlight Range Control Defective” warning on my dash when I start up, and it won’t go away.
    I’ve tried disconnecting/reconnecting the headlight, and have fully removed and refitted it. The headlight itself appears to be working.
    I connected a cheap diagnostic tool and it says there are no DTC codes, so I’m a bit flummoxed.
    Any ideas?
    Cheers,
    Ryan
  2. Re: “Headlight Range Control Defective” after headlight removal
    131 Post(s)
    1976 Post(s)
    Use a proper diagnostic system as the one you are using is probably only OBDII capable.
  3. Re: “Headlight Range Control Defective” after headlight removal
    Jul 2012
    United Kingdom
    Good point. I googled for “proper diagnostic system” but didn’t get any results . The tool managed to get the car’s information, rev count, etc., but is there something extra that’s a different system for the diagnostic codes? What should I be looking for?
    Cheers,
    Ryan
  4. Re: “Headlight Range Control Defective” after headlight removal
    Oct 2012
    Estonia
    64 Post(s)
    You need vcds or someone with vcds and probably recalibration of the lights is needed also.
    Maybe someone near to you has, try here:
    Vehicle Diagnostics Equipment - VCDS Information Only
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  5. Re: “Headlight Range Control Defective” after headlight removal
    Jul 2012
    United Kingdom
    Great, thanks .
  6. Re: “Headlight Range Control Defective” after headlight removal
    131 Post(s)
    1976 Post(s)
    VCDS is the easiest to use and ubiquitous.
  7. Re: “Headlight Range Control Defective” after headlight removal
    Mar 2012
    england
    I removed both my headlights to change bulbs then after a while wondered why my headlights were so low went in with vcds and you can bring them back up to level think the option was high delivery height and low or something like that and you also need to make sure you put it in the adjustment mode before moving the screws on the headlights
  1. Headlight Range Control Error
    By Staff68 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-09-2017, 04:07 PM
  2. Headlight range control defective
    By newa4b8sline in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-05-2013, 08:17 PM
  3. Headlight Range Control Warning
    By kid-jensen in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2011, 10:18 AM
  4. Question headlight range control
    By rhodie03 in forum Bora - 1998 - 2005
    Last Post: 06-11-2010, 01:56 PM
  5. headlight range control
    By rodaire in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2008, 02:20 PM
