Thread: Steering fault
Results 1 to 8 of 8
  1. Steering fault
    Dec 2010
    Wiltshire, UK
    6 Post(s)
    Has anyone experience the following fault come up on dash?
    Steering:
    System fault
    You can continue to drive
    Steering has got slightly harder. Park assist won’t work. Rear camera and parking sensors are working fine.
    Fault came up after trying to sort problem with tow bar electrics install.
    Any thoughts? It’s going into Audi tomorrow to have the car recoded for the tow bar install. Thought I would ask on here first before they try and tell me my steering rack is knackered. It happened while sat on my driveway.
  2. Re: Steering fault
    Jul 2018
    Waterford
    9 Post(s)
    Steering rack may need replacement unfortunately. If it's out of warranty, it could be around 2k....
  3. Re: Steering fault
    Dec 2010
    Wiltshire, UK
    6 Post(s)
    Doesn’t just break sat on the driveway and only 40k miles. If so Audi had better be ready
  4. Re: Steering fault
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Probably needs 'learning' again to tell it where its end stops are after the CAN fiasco
  5. Re: Steering fault
    Dec 2010
    Wiltshire, UK
    6 Post(s)
    Quote Originally Posted by morski View Post
    Thanks what I’m hoping for.
  6. Re: Steering fault
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    +1 on that! I was also assuming since the CAN stopped communicating, all sorts of fault codes will be present in most modules. Some will auto clear if enough clear driving cycles are performed, and some need VAS 5051 or VCDS to clear the codes first.
    You may find that turning the steering from lock to lock a few times and driving it may clear things, I'm not sure if this type of steering needs adapting or not?
    Very unlikely the rack has just broken.
  7. Re: Steering fault
    Dec 2010
    Wiltshire, UK
    6 Post(s)
    Well that’s how I see it too. It’s at Audi now so we shall see what they come up with. Hopefully their technicians can work the problem and figure it out.
    Back to good old faithful. 2009 Mondeo with 200k on the clock! (With a p f Jones towbar and wiring kit I fitted in 2011 that still works just fine!) lol
  8. Re: Steering fault
    Dec 2010
    Wiltshire, UK
    6 Post(s)
    Update from Bath Audi. All recoded and steering back to normal. Top service. CAN got a bit scrabbled by the sound of it but they’ve sorted it.
    Thanks for all the suggestions and help. Top forum this.
  1. Steering gear fault. Steering rack box knocking noise
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-08-2020, 06:46 AM
  2. Replies: 4
    Last Post: 08-03-2018, 01:41 PM
  3. Steering lock fault : system fault! contact workshop.
    By DJS11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-12-2017, 11:20 PM
  4. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
  5. Question Power Steering Fault
    By Witty in forum Ibiza - Cordoba
    Last Post: 12-12-2009, 10:47 PM
