Thread: Starting issue mk5 golf petrol
  1. Starting issue mk5 golf petrol
    Apr 2019
    Hi guys. Iv got a 2005 golf gt 2.0 fsi. If it’s been sitting for 12 hours it’s a bit slow to start. If I leave it for 24 hours it won’t start. Just keeps turning over until the battery goes flat sometimes splutters like it’s trying to start but no joy. I can hear the fuel pump priming but it won’t start. It’s fine when it’s running. It’s worth noting that when I jump start it, it turns over a bit faster and it starts straight away. Is it possibly the battery? Or a fuel pump issue? Any help will be greatly appreciated
  2. Re: Starting issue mk5 golf petrol
    May 2017
    Wrexham, N.Wales
    Do the headlights work ok? This is sometimes a sign of a flat battery. If the battery's fine it could be the starter relay. Have you plugged a code reader in to see if anything comes up?
    Sent from my H8216 using Tapatalk
  3. Re: Starting issue mk5 golf petrol
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    It sounds like the battery is struggling to hold a charge, can you check battery voltage with a voltmeter before cranking and immediately after cranking? It should be around 12.5V before and recover quickly after cranking, with the engine running you should see around 14 - 14.5v across the battery terminals. Some garages will do a free 'drop test' on the battery then try to sell you a new one.
  4. Re: Starting issue mk5 golf petrol
    133 Post(s)
    1987 Post(s)
    I would change the battery, modern starters are so efficient they will crank over on a battery that does not have sufficient voltage to operate the engine management, this often confuses people more used to the old fashioned symptoms of a flat battery.
  5. Re: Starting issue mk5 golf petrol
    Apr 2019
    Thanks guys, I’m buying a new battery and a starter relay tomorrow, gsf doing 60% at the moment and il get back to you and let you know how it goes. The car has a few little issues but I bought it for less than a grand with 100k miles. I want to work on it my self to learn a thing or 2
  1. Golf V5 AQN hot starting issue
    By markgrff17 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-11-2016, 11:41 PM
  2. Mk4 golf starting issue
    By Timdavisxo in forum Home Tech Shed
    Last Post: 04-07-2016, 10:49 AM
  3. Starting / stalling fault on 1999 Golf 1.6 petrol
    By 1999 Golf in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2015, 01:20 AM
  4. Question A3 2002 1.8 5v petrol starting issue
    By daveyboy467 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-03-2011, 08:22 PM
  5. Golf GT TDI starting issue
    By help in forum Archive posts
    Last Post: 15-10-2006, 02:15 PM
