Thread: Driver door handle wont open door broken ....pulley rod....help !
Hybrid View
  1. Driver door handle wont open door broken ....pulley rod....help !
    Apr 2013
    London
    Hi Guys, driver inner door handle is limp and wont open door, removed first vinyl main door inner panel and could pull the hook away from the handle and the steel rod slid up out of the sleeve with just a clean end so looks like its broken. From this point I am not sure whether to look into this further or take to a garage. What needs removing to enable me to get to the inner door section/lock where I can fit a new rod assembly ?
    Many thanks if anyone can help !
    Sam
  2. Re: Driver door handle wont open door broken ....pulley rod....help !
    134 Post(s)
    2009 Post(s)
    They are an awful job requiring the window frame shim wedges to be marked to TRY and help reassembly, a crazy system. If the window cables or the window lifter clamps look rough when they get in there, have a new mechanism fitted BUT they will need a huge rivet gun, for a 4 door model the rivets sharks are 6.4mm, even the 2 door ones are 4.8 and 6mm and it is not something you can bodge as the frame is box section alloy.
  3. Re: Driver door handle wont open door broken ....pulley rod....help !
    Apr 2013
    London
    Thanks Crasher so sounds like best I take it to a garage?..... you rekon this will cost a bit to sort out?
  4. Re: Driver door handle wont open door broken ....pulley rod....help !
    134 Post(s)
    2009 Post(s)
    Parts cost depends on what is broken. The official time is 120 time units (1 hour is 100 time units, only VAG would divide an hour by base 100) but that is a laugh, it takes that long just to get the subframe off! The main sketch will be parts, many, including the lock unit itself, are obsolete....
  5. Re: Driver door handle wont open door broken ....pulley rod....help !
    Jan 2009
    Nuneaton England
    6 Post(s)
    [QUOTE=Crasher;1102056]Parts cost depends on what is broken. The official time is 120 time units (1 hour is 100 time units, only VAG would divide an hour by base 100) but that is a laugh, Aston Martin, Jaguar and Land Rover do the same it takes ages to get used to in that an a hour is 100!!!! talk about make something simple harder!!!
    1 1 0
  6. Re: Driver door handle wont open door broken ....pulley rod....help !
    134 Post(s)
    2009 Post(s)
    I thought it was a VAG peculiarity
  1. passenger door wont open from inside or outside and driver window not working
    By nickeym1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:49 AM
  2. Please Help Interior door handle doesnt open the front door
    By stephenwhite990 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2012, 07:09 PM
  3. Replies: 0
    Last Post: 12-01-2012, 07:07 PM
  4. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  5. Golf driver's door handle forced (screwdrivered) and broken into
    By Mungler in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-06-2007, 08:01 AM
