Thread: Headlight beam moving up and down
Results 1 to 10 of 13
  1. Question Headlight beam moving up and down
    Jan 2009
    Hello all,
    looking for some help and advise if anyone else has has this problem before.
    My A6 C7 has xenon headlights where from yesterday the head light beam seems to be constantly moving up and down whilst driving.
    When the car is stationary it doesn’t seem to move apart from when I first noticed it they seemed to keep bouncing up and down slightly however haven’t seen that again just when driving.
    I have scanned the car for errors using VCDS however no fault codes are being found on the car at all.
    ant help would be great.
    Thanks,
    shahid
  2. Re: Headlight beam moving up and down
    135 Post(s)
    2042 Post(s)
    Both sides?
  3. Re: Headlight beam moving up and down
    Jan 2009
    Hello,
    Yeah it is both sides that are moving in sync together. I have managed to get a video recorded of it happening, it is attached.
    Thanks,
    Shahid
  4. Re: Headlight beam moving up and down
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Check the xenon level sensors on the front and back suspension arms. could possibly have been broken and not sending any signal back to the ecu
  5. Re: Headlight beam moving up and down
    Jan 2009
    Ok do you have to take the headlights out to check the sensors? Also would this not log an error code if no signal was being sent back?
    Thanks,
    Shahid
  6. Re: Headlight beam moving up and down
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    When my front one went I got a headlamp fault come up on the dash.
  7. Re: Headlight beam moving up and down
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    To me it looks like each time you went over a speed bump the lights decided to do their own thing! I wonder if a sensor is loose somewhere, the fact no sensors are reporting errors means they are working, but if they are loose and not mounted properly, could that cause problems?
    Audi RS4 2021 Carbon Black Edition
  8. Re: Headlight beam moving up and down
    135 Post(s)
    2042 Post(s)
    That looks like a broken level sensor pick up link on the suspension.
  9. Re: Headlight beam moving up and down
    Nov 2019
    Stourbridge
    Hello @shahid8850, I have exactly the same issue with my car! I have been searching and searching trying to find out what the cause and the solution is! I am hoping that you came across the answer and you are willing to share it?
  10. Re: Headlight beam moving up and down
    Nov 2019
    Stourbridge
    @gav28uk, in regards to this post I know its a few months old now, but you say if they are loose does that mean they are flapping around by the suspension and the sensor needs to be secured in order to really feel the adjustment in height? to confirm also this would be on the passenger side rear and front suspension?
  1. Please Help Headlight position moving up and down while driving
    By Rollsey in forum Golf MK6 - 2009 - 2013
    Last Post: 10-01-2018, 09:45 PM
  2. Headlight beam?
    By deano1978 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-11-2012, 10:41 PM
  3. headlight beam pattern
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-11-2009, 09:59 PM
  4. Headlight beam deflectors
    By bingoking in forum A8 - S8 - V8
    Last Post: 18-08-2007, 10:02 PM
  5. A4 Headlight beam deflectors
    By ian1234 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2007, 08:06 PM
