Thread: Allroad conked out , could this be injection pump
Results 1 to 10 of 18
  1. Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    hi All
    the wife was driving the normally trusty old 03 2.5 TDI Allroad home this evening, without warning at about 80 mph it conked out . She ended up stopped in the central reserve ! I got to her in about 20 minutes to tow her off the dual carriage way as after it conked out it wouldn’t start. When I got there it actually started but only on very low revs with glow plug light flashing. We limped it across the road and then I towed it home. She reported that earlier in the day the low oil warning flashed up big and red but immediately went off. She checked oil level which was fine and then carried on.
    now it will start and tick over but glow plug light flashing all the time and cuts out if I rev much over 1500 rpm
    ive just ran vcds. In the engine module I have 5 faults that are still there after clearing all DTCs
    00542 NEEDLE LIFT SENSOR (G80)
    30-10 open or short to plus - intermittent . Ive seen this one for a couple of years so I think it’s not the issue
    01268- QUANTITY ADJUSTER (N146)
    37-00 Faulty
    01381 - CONTROL MODULE FOR INJECTION PUMP (J399)
    37-00 Faulty
    01375 - VALVES FOR ENGINE MOUNTING; stage 1
    38-00- OUTPUT WONT SWITCH OR SHORT TO PLUS
    READINESS N/A
    A quick internet search shows 01268 and 01381 relate to injection pump
    01375 something to do with engine mounting
    any idea what might of happened and what I should do to check/repair ?
    any help much appreciated!
    cheers
    vin
  2. Re: Allroad conked out , could this be injection pump
    131 Post(s)
    1974 Post(s)
    Looks odd, not normally how I see a VP44 fail, I want to check the wiring diagram against the codes.
  3. Re: Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    Cheers Crasher
    any help much much appreciated as I’m at a loss at where to start
    in
  4. Re: Allroad conked out , could this be injection pump
    131 Post(s)
    1974 Post(s)
    I would check for water damage at the ECU plug.
  5. Re: Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    hi Crasher I keep the plenum chamber cleaned out every year but I will check it now and get back to you.
    cheers
    Vin
  6. Re: Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    Quote Originally Posted by vinpetrol View Post
    cheers
    Vin
    i just looked at a “similar thread “ and seen someone mention an ecu that is on top of the injection pump . Is that what you meant?
    cheers
    vin
  7. Re: Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    This is the wires going into the fuel pump . All looked ok in here .
    Is this the ecu wiring you mentioned to check?
    cheers vin
  8. Re: Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    Could it of jumped the timing ?
    it ticks over a bit rough and won’t rev hardly at all?
    cheers
    vin
  9. Re: Allroad conked out , could this be injection pump
    131 Post(s)
    1974 Post(s)
    We pride ourselves on keeping the plenum clean, my business partner John has a 2005 Allroad and suddenly last week it filled the passengers floor with water, he NEVER parks under bushes or trees anywhere and we clean the drains annually. There is the engine ECU in the box and the pump controller on the pump, we don’t mess with those we give the unit to a nice Bosch approved chap called Daryl at G Diesel.
  10. Re: Allroad conked out , could this be injection pump
    Sep 2008
    Highlands
    12 Post(s)
    Ok, plenum chamber is bone dry . Wiring into pump controller looked fine.
    Whilst im happy to remove my ecu or the pump controller and get them tested I’d like to exhaust any possibility’s I can check out myself prior to spending any money on a car that might be destined for the melting pot.
    could it off skipped timing ? Could this throw pump faults out ?,
    cheers for help
    vin
  1. Question A6 Allroad Injection pump swap
    By Ross Cottey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2016, 11:00 PM
  2. Replies: 9
    Last Post: 17-01-2016, 03:08 PM
  3. Power steering pump conked
    By iallen1@btinter in forum Golf MK6 - 2009 - 2013
    Last Post: 18-06-2010, 11:08 PM
  4. injection pump
    By bhoy7 in forum Toledo
    Last Post: 27-03-2008, 10:20 AM
  5. tdi injection pump
    By montymole in forum Touran - Sharan - Caravelle
    Last Post: 18-03-2008, 04:37 PM
