Thread: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
Results 1 to 10 of 18
  1. Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Hi All, i have a friends A6 2004 3.0TDI in at the moment, its had various issues but the main one i cannot fix is a constant stalling. i have read the threads on this, many variations there are too!
    the car sometimes is fine, it ran for a week with no issues, then it will go to only managing to tick over for 60 seconds before revs start to drop and it stalls.
    VCDS did show the fuel pressure rising to 800bar then drops straight to 200Bar then climbs back up over 5 seconds or so. then after a minute as i said tickover can be heard to drop and it stalls with the Glow-plug light flashing. re starts instantly off key. i have added a snapshot after i updated the firmware all faults fixed except for the 17471 ones
    Log-JIMBOB-WAUZZZ4F45N010246-287890km-178886mi-after cd.txt
    i have replaced the fuel filter, i have replaced the pressure switches on the rails i have opened both fuse boxes in the engine bay and there is no sign of water ingress, never the less i cleaned all the relay and contacts with circuit board cleaner. i have swapped the injectors from my 2006 car as i have read one chap had a faulty injector causing pressure issues. and up until yesterday it was still cutting out every 60 seconds even when cold. (doesnt stall when driving only at tickover)
    now last night i was checking connectors and unplugging things while it was running, i disconnected the plug on the fuel pump, low and behold it stopped stalling, however went into limp mode and would not rev over 3200 RPM it sat outside running for 30 minutes and did not stall once. so i reconnected the connector, and it hasnt stalled since.
    what is this part on the pump? is it pressure? or stop solenoid? (do they still have them?) anyway i have ordered new pins for this connector but im a little concerned as the pressure is still 480Bar and 29% even when warm, my other car is 280 cold "25% and 260 hot 19%
    is the pump faulty? or the solenoid on the pump? the car has done almost 180k now if that makes any difference?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    43 Post(s)
    Friday,01,April,2016,16:05:38:33186
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    Ross-Tech: Home
    VIN: WAUZZZ4F45N010246 License Plate: JIMBOB
    Mileage: 287890km-178886mi Repair Order: after cd
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
    61 62 72 76 77
    VIN: WAUZZZ4F45N010246 Mileage: 287890km-178886miles
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4F0 910 401 F HW: 4F0 907 401 A
    Component: 3.0L V6TDI G100AG 0030
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 02335 823 60092
    VCID: 1F478BA9CE3C7EC667-804A
    5 Faults Found:
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 002 -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.93 V
    Bin. Bits: 00101100
    Torque: 81.9 Nm
    Temperature: 67.5°C
    17953 - Throttle Valve Controller
    P1545 - 002 - Malfunction
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 11.93 V
    Duty Cycle: 92.7 %
    Bin. Bits: 010
    Mass Air / Rev.: 0.0 mg/str
    Voltage: 0.000 V
    17471 - Fuel Pressure Regulation
    P1063 - 001 - Control Range Not Reached
    Freeze Frame:
    RPM: 756 /min
    Torque: 46.8 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Pressure: 262.7 bar
    Duty Cycle: 27.2 %
    Temperature: 31.5°C
    P1063 - 002 - Control Range Not Reached
    Freeze Frame:
    RPM: 756 /min
    Torque: 46.8 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Pressure: 262.7 bar
    Duty Cycle: 27.2 %
    Temperature: 31.5°C
    P1063 - 005 - Control Range Not Reached - MIL ON
    Freeze Frame:
    RPM: 756 /min
    Torque: 46.8 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Pressure: 262.7 bar
    Duty Cycle: 27.2 %
    Temperature: 31.5°C
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0080
    Revision: 00000001 Serial number: 0018796
    Coding: 0000001
    Shop #: WSC 00539 210 17457
    VCID: 285590759B72B97E16-807C
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 A HW: 4F0 614 517 A
    Component: ESP8 quattro H03 0330
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    Shop #: WSC 02335 785 00200
    VCID: 2241825DFD4E532E48-8076
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 287890 km
    Time Indication: 0
    Date: 2016.04.01
    Time: 15:10:27
    Freeze Frame:
    Hex Value: 0x0280
    Hex Value: 0x40A2
    Hex Value: 0x0000
    Hex Value: 0x0096
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0220
    Revision: 31050601 Serial number: 10600300021983
    Coding: 0000019
    Shop #: WSC 00586 210 91538
    VCID: 63CFC759A2D41A2603-8036
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H43 0060
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H35 0020
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350EO047512758
    Coding: 0000002
    VCID: 254B9941EC60A4162D-8070
    Subsystem 1 - Part No: 4F0 910 609
    Component: Bedienteil MMIC6H03 0870
    Subsystem 2 - Serial number: 00000000009345
    Subsystem 3 - Serial number: 0126.04.040000000100010095’
    Subsystem 4 - Serial number: 010095’
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 287890 km
    Time Indication: 0
    Date: 2016.04.01
    Time: 15:10:27
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 HW: 4F2 820 043 C
    Component: KLIMABETAETIGUNGH11 0060
    Revision: 00000021 Serial number: 00000000018241
    Coding: 0001046
    VCID: 5BBFFFB99AA422E64B-800E
    1 Fault Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 287890 km
    Time Indication: 0
    Date: 2016.04.01
    Time: 15:10:32
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0003121
    VCID: 66C9DE4D51E66F0EE4-8032
    Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0040
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111
    Component: CD-Changer H43 0470
    Revision: 00000000 Serial number: AUZ5ZBD4000388
    Shop #: WSC 00000 000 00000
    VCID: 1C3DBCA5DF2A65DE82-8048
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 G HW: 4F0 959 655
    Component: 20 AIRBAG AUDI8RH24 0110
    Revision: 07H24000 Serial number: 00358D05BE8O
    Coding: 0012848
    VCID: 2B5F6F798A849266FB-807E
    Subsystem 1 - Serial number: 6332CSME02420C2D$
    Subsystem 2 - Serial number: 6342CSME0261652C$
    Subsystem 3 - Serial number: 6351HSME0230436B$
    Subsystem 4 - Serial number: 6361HSME020C0354.
    Subsystem 5 - Serial number: 6371VSME014801759
    Subsystem 6 - Serial number: 6381VSME024C0075E
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H06 0130
    Revision: 00H06000 Serial number: 90025041200048
    Coding: 0102141
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 H
    Component: KOMBIINSTR. M73 H07 0630
    Revision: 00600000 Serial number: 49F36Y554
    Coding: 0065443
    Shop #: WSC 00428 067 57207
    VCID: 1E39B6ADC93677CE6C-804A
    Coding: 0065443
    Address 19: CAN Gateway Labels: 4F0-910-468.clb
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 0800804424025B
    Coding: ECFE73C41B1104
    VCID: 27579349966CB6061F-8072
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 287890 km
    Time Indication: 0
    Date: 2016.04.01
    Time: 15:10:29
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: 72
    Coding: 0000538
    VCID: 295395718078807609-807C
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H14 0090
    Revision: 00900014 Serial number: 01000177750000
    Coding: 0131571
    VCID: 2C5D6C658F8A955EF2-8078
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0010
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 11S00001 Serial number: 00705040010258
    Coding: 0000001
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H07 0040
    Revision: Serial number: 00000000007571
    Coding: 0001103
    VCID: 5EB9F6AD89B637CE2C-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: x‘
    Coding: 0000538
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C63C0030 H03 0030
    Revision: C63C0030
    Coding: 0000321
    VCID: 5DBBF1A184B02CD635-8008
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
    Component: AFS 1 H03 0010
    Coding: 0000016
    Shop #: WSC 02327 785 00200
    VCID: 244D8445E75A5D1E3A-8070
    Subsystem 1 - Part No: 4F0 941 329
    Component: AFS-Modul links H05 0010
    Subsystem 2 - Part No: 4F0 941 329
    Component: AFS-Modul rechtsH05 0010
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541
    Component: TUNER EU/US/RDW H41 0630
    Revision: 00000000 Serial number: 352DG047520903
    Coding: 0000001
    VCID: 31637D11A8A8F8B6C1-8064
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H11 0490
    Revision: 00000000 Serial number: 00000000011657
    VCID: 234F8759E2545A2643-8076
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 0404270089
    Coding: 344630393135313035442056413030343034323730303839
    Shop #: WSC 00000 640 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
    Component: TSG HL H09 0010
    Coding: 0000002
    VCID: 2A516A7D857E8B6E00-807E
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
    Component: TSG HR H09 0010
    Coding: 0000002
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 HW: 4F0 919 283
    Component: Parkhilfe 4-Kan H09 0020
    Revision: --.--.-- Serial number: 11730412405139
    Coding: 0001006
    VCID: 61C3CD51B8C8083611-8034
    Address 77: Telephone Labels: 4E0-910-333.lbl
    Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
    Component: TELEFONMODUL EU 0770
    Revision: 00000003 Serial number: T2AUDX0307H3S4
    Coding: 0000006
    End-------------------------(Elapsed Time: 02:49)--------------------------
  3. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Nov 2012
    Somerset UK
    Dean, have a look at these two threads:
    Engine struggles to start and cuts out when coasting
    Fuel pump in fuel tank
    Like you I had fuel pressure issues.
  4. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by dean warren View Post
    This is N290 , fuel metering valve , google SSP 351 ( The common rail fuel injection system fitted in the 3.0l V6 TDI engine ) page 12 has info . Via the Audi dealer route you won't be able to buy the valve but you can via VW commercial dealer (see this post). Not saying you need to replace it but just as info for yourself/another . Google SSP 350 as well, another handy PDF to have but 351 is better for context of CR system.
  5. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    43 Post(s)
    Interesting, so it is pressure.
    As you say though, still no idea if its that or not thanks anyway.
  6. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Sep 2011
    No worries, sorry got no exact answer.
    Wjam viewed his valve, post 11 . In his other thread it seems to me measuring block data (or if you tested the sensor via output test using VCDS) are showing basically ECU requests for it to open/close but not what it's actually physically doing, unless it failed electrically you may not get a fault code on it. This could also be true of N276. If you view MVB 22 that will have specified rail pressure (what ECU want) and actual (what rail sensor is reporting), window 4 of MVB 22 is telling you activation % of N276 IIRC (see the 3.0 TDI mvb thread) and window 4 of MVB 23 is telling activation % of N290 IIRC.
  7. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    43 Post(s)
    Ive ordered a valve to try, as the other chap had exactly same pressure as mine, so worth a punt
  8. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Nov 2012
    Somerset UK
    Any updates Dean?
    I know the part no is 0928400572
    But where is it actually fitted, the Fuel pressure regulator is on the left hand bank and the fuel pressure sensor on the right, but have traced back fuel lines and electrics and can't find anything that looks quite like that.
    My problems have returned and my fuel pressure is approx the following on all 6 injectors:
    Pressure: 745.5 bar
    Duty Cycle: 57.2 %
  9. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    43 Post(s)
    Its on the back of the pump.
    It hasn't stalled since but to be fare i haven't used it much, its a second car and my insurance said i could only add it for 14 days.
    I have a trade policy starting next month so will crack on then.
    To fit i had to remove the bank one inlet for access and then 3 very tight torque screws hold it in.
  10. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    43 Post(s)
    My pressure still reads 470/480 bar on tickover, this is a 2004 car, our other two show 280bar but there 2006 and 2007 so think have a different revision pump.
  1. High fuel pressure A6 2.0 tdi 170 ps
    By Sambor11 in forum VCDS - General Questions
    Last Post: 14-03-2016, 08:35 PM
  2. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  3. Fuel Pressure PSI/BAR?
    By pizzaboy150 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-08-2013, 01:40 PM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2010, 10:25 AM
  5. Question 4 Bar Fuel Pressure regulator.
    By comfortablynumb in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2009, 03:29 PM
