Thread: Rough shutdown CFFB
  1. Post Rough shutdown CFFB
    Wales
    Car is shutting off albeit untidy (rough) intermittently , I have only noticed this happening after recent EGR replacement , Unsure if its related ofc , but I have tried a forte fuel cleaner in case of a suspected clogged or dirty injector , its an intermittent issue but wasn't there before . Any ideas anyone ? Garage cant see any problems , no codes present or leaks around injectors.
  2. Re: Rough shutdown CFFB
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The throttle valve closes on shutdown to force the engine into a quick stop.
    It is located just below where the EGR gasses enter the inlet stub at the front of the engine.
    As miles increase, " gunge " from the EGR gasses run down under gravity into the throttle valve & start to obstruct the butterfy valve from operating properly, which may be the case here.
    So would be a good idea if you remove the throttle valve & give it a good clean.
    While removed, remove as much of the EGR crap that will have built up in the inlet stub where the EGR discharges into it.
  3. Re: Rough shutdown CFFB
    Wales
    Thank you very much
  1. Please Help Crafter - electrical shutdown
    By jhenry in forum The Commercial Range
    Last Post: 01-08-2022, 11:44 AM
  2. Egr cffb
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 11-08-2019, 02:41 AM
  3. Replies: 0
    Last Post: 20-02-2019, 02:09 AM
  4. Question Rough Shutdown - Im stumpped
    By adani24 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-09-2018, 08:58 AM
  5. RNS-D Snags: Auto shutdown and TP
    By Overdose in forum In Car Entertainment
    Last Post: 26-01-2018, 09:05 PM
