Thread: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
  1. Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All
    Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Help
    A few days ago the tick over started fluctuating between 700rpm > 1200rpm and very rough - when driving above 2500rpm all seems good
    Checked fault codes with Vagcom - P1340 Camshaft position sensor - Engine speed sensor - Incorrect correlation?
    Checked cambelt timing all OK
    Checked internal cam chain drive all OK
    Replaced camshaft sensor - fault still there
    Replaced crankshaft sensor - fault still there
    Carried out oil and filter change - incase the oil pressure was affecting the internal cam chain tensioner - fault still there
    Anyone got any ideas please?
  2. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    Jan 2009
    Nuneaton England
    6 Post(s)
    Update been out to the car and it would not start!!
    Checked fault codes and P1340 present!!
    Clear code engine started and ran OK for a few seconds then the lumpy tick over returned
    Drove the car round the block checked fault codes now I have:
    (16725) P0341 Camshaft sensor implausible signal ?
    (17748) P1340 camshaft position sensor / engine speed sensor - inco correlation
    (16684) P0300 random multiple cylinder misfire detected
    (16685) P0301 cylinder 1 misfire detected
    (16686) P0302 cylinder 2 misfire detected
    It looks like my poor car as going from bad to worse, please HELP
  3. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    134 Post(s)
    2005 Post(s)
    Your sump pick up is blocked, stop running it or you will kill the turbo and then the engine, if you haven't already.
  4. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    Jan 2009
    Nuneaton England
    6 Post(s)
    Many thanks Crasher
    Sugar - OK thanks I will be busy this evening to then. Do I need any special tools to remove the sump?
    A quick question though, how does this cause the fault/faults I am seeing? (I am just curious as to why)
  5. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi @Crasher / All
    Sump removed cleaned, oil pick up removed cleaned, pick up refitted, sump refitted. Clean new oil and filter
    Start up left to run for 10>15 minutes same fault codes present:
    (17748) P1340 camshaft position sensor / engine speed sensor - incorrect correlation
    Removed valve cover, inlet camshaft, cam chain, cam chain tensioner. Installed new cam chain and tensioner
    Startup left to run for 10>15 minutes, same fault codes present:
    Could it be there is a fault with the oil pump??
    Please any help / suggestions
  6. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    134 Post(s)
    2005 Post(s)
    You need to check the oil pressure at idle, I suspect you have damaged crank bearings, I have seen this a lot on the 1.8T and now we are seeing it on the 2.0T, twice last week alone, I have a 2012 TT 2.0T sitting at work ready for next week, low oil pressure caused the turbo to snap its shaft.
  7. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    Mar 2016
    Minervois, France
    54 Post(s)
    I seem to be hearing about more and more problems possibly related to 1.8T oil pickup problems.
    I'm in the process of fitting an oil pressure gauge - don't know why so few cars seem to have them.
    mumutley, could you please post your current mileage and what oil change interval you follow?
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  8. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    134 Post(s)
    2005 Post(s)
    For some odd reason it is more of a problem on the longitudinal installation engines than transverse, I can’t decide if it is air flow related or the shallow rear surface as that does seem to be where the sludge is generated but changing the oil every 9000 miles and using the best money can buy seems to stop it occurring.
  9. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    Mar 2016
    Minervois, France
    54 Post(s)
    Fingers crossed then. I'm using fully synthetic Shell Helix Ultra 5W40, and from now on intend changing the oil and filter every 8,000 km (5,000 miles), which for me is about once a year.
    Changes so far have been made at 7,000, 5,100 and 4,400 miles.
  10. Re: Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    134 Post(s)
    2005 Post(s)
    I do mine and Mrs Crashers once a year (both a 1.8T) and use Quantum Longlife which is now made by Fuchs, I do barely 3k and her about 5 and both engines are spotless inside the sump as I also use a probe.
  1. Replies: 0
    Last Post: 18-01-2016, 03:26 PM
  2. Replies: 0
    Last Post: 18-01-2016, 02:26 PM
  3. Please Help Engine code fault p0015???? Help please a4 3.0 quattro
    By davespeedie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-07-2011, 11:21 PM
  4. 3.0 Quattro engine management fault code help needed
    By scottishpaul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2011, 09:34 AM
  5. audi a4 1.8 t 2002 fault code
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-05-2010, 04:12 PM
