Thread: low oil pressure STOP, oil pump?
Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
  1. Re: low oil pressure STOP, oil pump?
    #51
    Jan 2012
    Rustington, West Sussex UK
    9 Post(s)
    87 Post(s)
    Quote Originally Posted by johnro79 View Post
    i went and got a KMB pump and kit 10 for my car
    i have oil +filter + sealant (V-Tech Vital Copper RTV Gasket Makers-85gm)
    unless anything else is bad ore just can't be reused, what else do i need to have handy?
    monday or tuesday gonna take the sump off and see what's in there
    If you do end up replacing the balance shaft you will need the 8 balance shaft mounting bolts which are single use only (TTY)
    As the balancer unit is seriously heavy I would not skimp and reuse the mounting bolts for the sake of 40 odd quid and would use new bolts. The ones holding the 2 halves of the balance unit are imo ok to reuse as the exact replacements and also the special shells / bushings inside the unit cannot be sourced from well, anywhere I know of in the UK. I do see refurbished balancer units with new shells online but have no idea where to source the new shells which have a cut out to match to the oil channels and are fairly small. I have seen a Polish video of a workshop refurbishing these balancer units and if anyone knows where to get the specific shells / bushings I would be eternally grateful, as I would like to renew mine whilst I am changing my main and rod bearings. I might just get a refurb u it for 350 but would prefer not to spend that much.
    Mad Mitch
  2. Re: low oil pressure STOP, oil pump?
    #52
    Apr 2016
    London/UK
    22 Post(s)
    how important is the timing locking tool thingy?
    do i really need that one if i'll replace the balancing shaft or that's mostly for when you do just the oil pump?
    can i do without by any chance?
  3. Re: low oil pressure STOP, oil pump?
    #53
    82 Post(s)
    1405 Post(s)
    How do you think the engine will feel if a dirty great off centre weight is in the wrong place?
    Slava Ukraini!
  4. Re: low oil pressure STOP, oil pump?
    #54
    Apr 2016
    London/UK
    22 Post(s)
    I know what you mean
    I was thinking more like, since my car does not have belts or chain, when you replace the balancing shaft , you can slot it in the propper way , balanced/in line with the counter weight one
    Surely they have markings/dots on them and you can visually see if its balanced or not. Am I wrong?
  5. Re: low oil pressure STOP, oil pump?
    #55
    82 Post(s)
    1405 Post(s)
    The procedure is crank locked with a timing plate, the slotted wheel tipped up and key in slot, holding the key in whilst you find the
    right place for the slotted gear by pressing (hard) in the NEW intermediate gear in with a non metallic block such as a rubber pad.
    Just had two blokes in the e holding an oil pump "me mates changed this and still got no pressure" we showed him a worn drivekey, "have you changed this sir?"... "no mate"... FFS
    Slava Ukraini!
  1. Please Help STOP. Low oil pressure
    By TaximanWsM in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 12:39 PM
  2. Oil Pressure Stop Help please
    By parkerm35 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2013, 03:14 AM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Stop!!! Low Oil Pressure!!!!!
    By bubblesaint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-03-2011, 04:43 PM
  5. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
