Thread: low oil pressure STOP, oil pump?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
  1. Re: low oil pressure STOP, oil pump?
    #11
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by aj1soad View Post
    Attachment 35779just got this from them so it doesnt look like theyve given me a price for the correct part, thats just the oil pump and not the kit or balance shaft
    Wrong job - not likely to be anything wrong with the oil pump itself so no, this garage does not know the likely cause of the low oil pressure warning. Very outside chance of it being a failed oil pump or even failed oil pressure sensor but from what you have said about the sounds you heard and our experience of these engines tells most on here that it is likely to be the balance shaft and oil pump DRIVE bar.
    Visual inspection the only way to confirm.
    Mad Mitch
  2. Re: low oil pressure STOP, oil pump?
    #12
    May 2012
    Everywhere
    308 Post(s)
    It will be gear driven , Kit 9 .
  3. Re: low oil pressure STOP, oil pump?
    #13
    2024 Post(s)
    The only way you will know what to do is by dropping the sump. You have stated it has been worked on in this area before so no one has any idea what is in there
  4. Re: low oil pressure STOP, oil pump?
    #14
    Jan 2015
    Nottingham
    Hello aj1soad
    If that light as come up on your dash. I would suggest you do not drive the car. You could be destroying your turbo and engine.
    You will not be able to see the Allen key without taking off the sump. As it is within the balance shaft . That key is what spins the oil pump.
    I am not as knowledgable as some people on here but I have done the replacement Allen key on My 08 Passat .
    You will get some help from someone soon
    I hopes this helps
  5. Re: low oil pressure STOP, oil pump?
    #15
    2024 Post(s)
    I would be surprised if it had the chain drive, but I can tell if it was built with one by the VIN
  6. Re: low oil pressure STOP, oil pump?
    #16
    Aug 2019
    Telford Shropshire
    9 Post(s)
    I have the same problem with my car oil pump failure 🤦*♂️... Mine is an auto 2007 dsg... I've only just had mine replaced and a month later the oil pressure light has come on again 😔 don't know why it is failing or there could be other internal problems...
  7. Re: low oil pressure STOP, oil pump?
    #17
    May 2012
    Everywhere
    308 Post(s)
    Quote Originally Posted by Nabz1310 View Post
    I have the same problem with my car oil pump failure 臘*♂️... Mine is an auto 2007 dsg... I've only just had mine replaced and a month later the oil pressure light has come on again  don't know why it is failing or there could be other internal problems...
    What exactly did you replace ?
  8. Re: low oil pressure STOP, oil pump?
    #18
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Quote Originally Posted by Gazwould View Post
    Just the oil pump from euro car parts bud and key
  9. Re: low oil pressure STOP, oil pump?
    #19
    May 2012
    Everywhere
    308 Post(s)
    So the actual oil pump cassette and drive key .
    You didn't address where the other end of the key goes , the balancer shaft keyway which would of been worn inside .
  10. Re: low oil pressure STOP, oil pump?
    #20
    Aug 2019
    Telford Shropshire
    9 Post(s)
    No buddy.. Unfortunately not... should have replaced that too. I'm guessing?? 😔 basically balance shaft and hex keys should have been replaced also? Links to pics would help me alot mate... Thanks in advance
  1. Please Help STOP. Low oil pressure
    By TaximanWsM in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 12:39 PM
  2. Oil Pressure Stop Help please
    By parkerm35 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2013, 03:14 AM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Stop!!! Low Oil Pressure!!!!!
    By bubblesaint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-03-2011, 04:43 PM
  5. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
