Thread: low oil pressure STOP, oil pump?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
  1. Re: low oil pressure STOP, oil pump?
    #21
    May 2012
    Everywhere
    308 Post(s)
    What engine code mate ?
  2. Re: low oil pressure STOP, oil pump?
    #22
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Quote Originally Posted by Gazwould View Post
    cars recovered to a mates garage I will be able to post it soon just txt him.
  3. Re: low oil pressure STOP, oil pump?
    #23
    Aug 2019
    Telford Shropshire
    9 Post(s)
    engine code BMR - wvwzzz3cz8e022021
  4. Re: low oil pressure STOP, oil pump?
    #24
    May 2012
    Everywhere
    308 Post(s)
  5. Re: low oil pressure STOP, oil pump?
    #25
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by Nabz1310 View Post
    No buddy.. Unfortunately not... should have replaced that too. I'm guessing?? �� basically balance shaft and hex keys should have been replaced also? Links to pics would help me alot mate... Thanks in advance
    The oil pump itself would most likely be fine and not have needed to be replaced. Probably changed a good oil pump for a new oil pump when it was the balance shaft and Allen key that needed replacing.
    I have a BMR and have done the job myself quite a few times now and for friends and workmates if you need further DIY help or have any questions.
    Mad Mitch
  6. Re: low oil pressure STOP, oil pump?
    #26
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Quote Originally Posted by DMitch16 View Post
    True mate ... But the fact is now i have to get all the rest changed lol 😂 oh well lesson learned... i just need to figure out where to get the parts from 🤔 so i can get it done once and for all 🤦*♂️.. I've only got 153k on the clock full service history well looked after car too..
  7. Re: low oil pressure STOP, oil pump?
    #27
    Aug 2019
    Telford Shropshire
    9 Post(s)
  8. Re: low oil pressure STOP, oil pump?
    #28
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Cool will hit u up if i get stuck on anything... After ordering kit 9 as gaz mentioned hopefully that will be all i need ��
  9. Re: low oil pressure STOP, oil pump?
    #29
    Jan 2012
    10 Post(s)
    88 Post(s)
    You'll need a bit more than that
    Timing locking tools including balance shaft alignment block
    New balance unit mounting bolts (8 total but 3 sizes)
    Elring Dirko HT sealant for sump
    New retaining circlip for Allen bar
    Don't get the balance shaft alignment block piece from KMB as it is far cheaper elsewhere and even comes in some of the PD timing tool kits which strangely often only have one cam lock pin not two in those ones? Bit odd but it is what it is.
    Mad Mitch
  10. Re: low oil pressure STOP, oil pump?
    #30
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Cool thanks 👍 if u can send me some links to purchase those items that would be great.....
    sealant isn't a problem i have some of that left over from before. Regards
  1. Please Help STOP. Low oil pressure
    By TaximanWsM in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 12:39 PM
  2. Oil Pressure Stop Help please
    By parkerm35 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2013, 03:14 AM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Stop!!! Low Oil Pressure!!!!!
    By bubblesaint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-03-2011, 04:43 PM
  5. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
