Thread: poor idle oil pressure light
  1. poor idle oil pressure light
    hi guy hope you can help me out hear my mk2 1300 golf seems to idle poor and when i turn the lights on the idle speed drops and the oil pressure warning buzzer comes on soon as i give a bit of throttle all is good again it drives really well just this problem when idle
  2. Re: poor idle oil pressure light
    ireland
    first check your oil level just in case
    are you sure its the oil light and not battery light?
    rough idle could be due to worn rubber carb mounting plate
    look for tears in the rubber (its just under the carb )
    or run on idle and with both hands slightly move carb forward , backward and side to side .if the rubber plate is torn you should hear the engine revs drop or it may cut out .if this happens you need a new one .
    think its only available from vw main dealers
  3. Re: poor idle oil pressure light
    hi it is the oil pressure light i have plenty oil and have worked out that they are not related problems i will try a new rubber mounting
  4. Re: poor idle oil pressure light
    SOUTH WEST ENGLAND
    Maybe alternator playing up??? Had the same problem with my mk2 jetta 1.3 (same engine)
    ../.___________.\.. VW MK2
    ./( )========( )\. JETTA
    |\______ _______/| 1990 1.6 TX
    |_\_____ ______/_| I♥MY DUB
  1. poor idle
    By lee07 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-11-2007, 07:29 PM
  2. Poor idle on tdi when cold
    By tezray in forum Archive posts
    Last Post: 15-09-2007, 03:20 PM
  3. Oil Pressure light A4 18T
    By Leigh A in forum Audi A4 - Archive Topics
    Last Post: 28-08-2007, 01:59 PM
  4. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
