Thread: Golf 1.6 tdi cayc miss fire
Results 1 to 10 of 14
  1. Golf 1.6 tdi cayc miss fire
    Dec 2008
    Hi, can some please help me. I have a 2010 golf 1,6 tdi which has a miss fire on idle and a slight knock on low rev. There are no fault codes stored, but done a check on injectors om idle and they are : inj #1 mg/ stroke 3.4360. Inj #2 mg/stroke -1.6022. Inj #3 mg/stroke -1.3036. Inj#4 mg/stroke -0.4696. Does these readings tell if any injectors are duff.
  2. Re: Golf 1.6 tdi cayc miss fire
    134 Post(s)
    2012 Post(s)
    It implies number 1 is faulty BUT it can be a misleading and you find it being number 3. Obviously the ideal solution is four new injectors but that would exceed the cars value. DO NOT be tempted by aftermarket injectors except genuine VDO units in sealed VDO packets, reject one that has been opened. Genuine VW injectors (03L 130 277 SX) are £476.26 each but you can get VDO units for a little less at £445Siemens VDO Injector | Euro Car Parts and it is telling they have 2811 in stock..... Remember these MUST be coded into the ECU or they will not work correctly and you must use new retaining bolts and new seals for the paired injector you have to remove.
  3. Re: Golf 1.6 tdi cayc miss fire
    Dec 2008
    Thanks crasher, i am right in saying they all have to be minus on idle.
  4. Re: Golf 1.6 tdi cayc miss fire
    134 Post(s)
    2012 Post(s)
    Not necessarily, they wander around but anything over +/-1 attracts my attention
  5. Re: Golf 1.6 tdi cayc miss fire
    Dec 2008
    Thanks crasher, I will buy a new injector and try it
  6. Re: Golf 1.6 tdi cayc miss fire
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    When VAG-COM\VCDS shows a component or cylinder that refers to the cylinder in firing order not component number.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  7. Re: Golf 1.6 tdi cayc miss fire
    Leicestershire
    8 Post(s)
    Quote Originally Posted by kevin b View Post
    I have a very similar problem just worse. When the engine is cold anything under 2000 rpm is really really awful. Whatever you are thinking just think worse than that.
    Did you take the injectors out for testing?
    How did you get on with the one you replaced?
  8. Re: Golf 1.6 tdi cayc miss fire
    134 Post(s)
    2012 Post(s)
    A very difficult one, if they were £500 a set fitted then you could take a deep breath, fit them and be pretty sure you were going to solve the problem and if it didn’t, well it’s not the end of the world but when they are £2500 fitted AND you are sure the near £2000 fitted high fuel pump is perfect as this can ruin new injectors, well it all gets quite frightening when you are in £5k and the thing still runs like ****!
  9. Re: Golf 1.6 tdi cayc miss fire
    Leicestershire
    8 Post(s)
    Now that is very worrying... and no way to tell if the fuel pump is the problem?
    I’ve had diesel for 12 years now.. the faultless A3 tdi sport and now this pile of junk. Might be time to go back to petrol
  10. Re: Golf 1.6 tdi cayc miss fire
    134 Post(s)
    2012 Post(s)
    You can study the pumps pressures and the injector attitudes, and also check the fuel filter for swarf but in doing that you expose the pump to damage from an air lock so the system MUST be bled, this is when almost all pump failure seems to occur and it fills the injectors with swarf which you cannot get out. As you can imagine trying to advise a customer on this issue is stressful.
  1. Golf mk5 1.9tdi miss fire issue
    By Orange Triffid in forum Golf MK5 - 2004 - 2009
    Last Post: 14-12-2015, 04:05 PM
  2. Miss fire on a MK4 Golf 1.6
    By shiam04 in forum New Member Introductions
    Last Post: 17-07-2015, 03:43 PM
  3. Baffling miss fire at 3-4k revs on 1999 golf gti turbo 1.8.
    By Tommer9 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2014, 06:26 PM
  4. Low rev miss-fire
    By A303 in forum 100 - 200 - Turbo - 100 S4
    Last Post: 12-05-2010, 03:32 PM
  5. golf 1.8t low revs miss fire judder.
    By scambo69 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-02-2009, 07:22 PM
