Thread: Polo 1.4 Cl, V Reg wont start
Results 1 to 10 of 14
  1. Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    Since yesterday morning my Polo can be started only by RAC rescue after spraying ‘carburettor liquid’ in throttle (below air filter), I can restart as long as it’s warm. Once it left overnight again same problem. All spark plugs, cable are fine.
  2. Re: Polo 1.4 Cl, V Reg wont start
    131 Post(s)
    1974 Post(s)
    More than likely the coolant temperature sender is stuck on a high reading so the computer isn't adding extra fuel during cold start. Did the RAC man scan for fault codes?
  3. Re: Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    I think you are right, in morning coolant level was way below minimum mark, I have already topped it up. I would try to start it again in morning.
    RAC guy din't had diagonstic eqp. I have already VAG COM cable and software to scan fault codes, RAC guy also thougt it could be one tempreature sensors, but I have have no idea where it is located and how to replace it.
  4. Re: Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    Quote Originally Posted by crauch6 View Post
    just tried to start again, won't start..
  5. Re: Polo 1.4 Cl, V Reg wont start
    131 Post(s)
    1974 Post(s)
    Loosing coolant is nothing to do with the coolant temp sender unless the seal is leaking which is rare. On that engine I would now be concerned about a possible head gasket fault. Take off the oil cap and see if the back of it is covered in a yellow goo we call mayo for obvious reasons. You have VAG-COM so what codes do you have?
  6. Re: Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    I would be doing code scan over the weekend.
    Yesterday evening it started again and I drove it for 2-3 miles, while driving it's perfectly normal.
    I would check oil for any mayo today.
  7. Re: Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    I have oil cap checked yesterday there in no indication of yellow goo, I have received my vag com cable and software today. Most probably it's coolant tempreature sensore, but after scanning codes I would let you know. There is no oil on the driveway so I am not sure it's head gasket fault.
  8. Re: Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    Hi, just performed full vag com scan, no fault codes. Should I go ahead and change coolant temp sensor. Any help in this matter would be very much appreciated.
    Also if somebody can pls. let me know how to change coolant sensor.
  9. Re: Polo 1.4 Cl, V Reg wont start
    131 Post(s)
    1974 Post(s)
    The coolant temperature sensor is located below the distributor in a black plastic water housing. Make sure the engine is cold and release the coolant expansion tank cap. Locate the sensor in the housing and squeeze the two metal ears of the plug retaining clip and pull the plug off. Release the sensor by sliding out the metal or plastic retaining clip. Pull out the sender and retrieve the "O" ring from inside the hole. Reassembly is the reverse of removal as Haynes would say. Give me your chassis build year letter (wvwzzz6Nz ? Yxxxxxx) and engine code and I will give you the part number.
  10. Re: Polo 1.4 Cl, V Reg wont start
    Surbiton, Surrey
    Hi, thank you very much for details for coolant sensor, I am also attaching picture just to make sure that I am looking at the right place.
    chasis build & year wuwzzz6n z xy381037. one last thing should I buy it from vw dealer or euro parts.
  1. A4 1.8T wont start!!!
    By antix1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-09-2007, 03:02 PM
  2. Polo wont start
    By nige61 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-04-2007, 10:23 PM
  3. a6 1.8t wont start
    By loco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-01-2007, 10:22 PM
  4. a6 1.8T wont start
    Last Post: 06-01-2007, 12:21 AM
  5. Polo GT suddenly wont start
    By biggles0509 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-12-2006, 10:58 AM
