Thread: No turbo Acceleration
  1. No turbo Acceleration
    Feb 2019
    West London
    Hello,
    up
    I own a passat 1.9tdi 2003 which runs and drives but lacks acceleration. The car is not smoking and there are no engine warning lights. I plugged my diagnostic in and am getting no codes. The boost pressure sensor is reading a constant 22.3psi. The turbo is spinning up with suction when running and turns freely by hand with no binding. There are no abnormal sounds from the engine.
    The egr valve was fairly clogged up but flap turns freely, the valve inside however i think is seized but i need to test it properly and will give it a good clean.
    All the pipes are in good condition with no leaks.
    What should next in my list of checks?
    Im a motorcycle mechanic with a good variety of tools getting into my cars but bikes dont have turbos
  2. Re: No turbo Acceleration
    132 Post(s)
    1980 Post(s)
    The boost should be circa 1000 mBar with the engine off, i.e. atmospheric, yours is showing circa 1500 mBar. The sensor stops at 2280 mBar What are you reading the codes with, an OBDII reader? Does the engine have no power all the time or drive OK and then loose power until the ignition is cycled again.
  3. Re: No turbo Acceleration
    Feb 2019
    West London
    it has no power all the time. The readings are through a ob2 tester
  4. Re: No turbo Acceleration
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    " The boost pressure sensor is reading a constant 22.3psi "
    Is this with the engine just ticking over as well.
    If so, Map ( thrust sensor ) is probably faulty.
  5. Re: No turbo Acceleration
    132 Post(s)
    1980 Post(s)
    The MAP sensor should read 1 bar with the ignition on, if it is much more then it is stick and FUBAR.
  1. Blown turbo. Is it possible to replace a k03 turbo with k04 turbo
    By A4slineavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2012, 07:45 AM
  2. Question TDI 170 + 140 Acceleration
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-08-2011, 03:21 PM
  3. No acceleration after turbo cahnge
    By bag320 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-05-2011, 02:36 PM
  4. Question Acceleration 3.0 Cab
    By ringo_the_audi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2010, 05:17 PM
  5. Passat 1.8 20v turbo, hunting on idle & poor acceleration
    By vwpassat1.8juic in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-12-2008, 09:39 AM
