Thread: Alarm fault on a6
Results 1 to 10 of 14
  1. Alarm fault on a6
    Hi all i,m wayne ..new member.... I have a problem with my alarm the car is a 2000 A6 2.5tdi. quattro......v6 the alarm is factory standard.boot alarm (i tink). For the last 3 week the alarm has been activating on it own..at really irregular time . 4am - 12 pm just all kinds of time . if i unlock the car then lock it it will just continue to go off untill it feels like stopping. and other people in the road are none to pleased..neither is my wife lol (I make her go and switch it off at 4 am lol) if i leave the car unlocked its fine ..
    any ideas at all would be great..
    ho yeah i have made sure that all the door and windows are fully locked..when it happens.and some times if i open the boot then slam it shut the alarm SOMTIMES will not go off again ..untill like 2 hours - 3 days later
    any would be gr8 its drivin me
    many thanks
    UPDATE o ho :0--
    OK up date on problem.Tonight i started the car..break light warning light came on .after cheacking the lights .i found that ns break light out and fos indicator not working..Also ABS light esp light and coil light all on on the dash ......I KNOW bad news is on its way ,,
    is there any topical fault with water ingress known of with the a6 in genral ..?
    or a earth fault on the electrics that is common ?????..
  2. Re: Alarm fault on a6
    Jul 2007
    Cheshire, or my A6
    There was a recall on some A6's about water getting into the passenger footwell via some sort of plate behind the battery. After driving in the rain, check if you have water under the carpets in the passenger footwell. There is some sort of electronic control system there which controls many of the electrical systems the car has, and when that gets wet it does all sorts of crazy things.
    Paul
  3. Re: Alarm fault on a6
    nice one mate TY paul i,ll go check right now ....thanks
  4. Re: Alarm fault on a6
    Mar 2007
    Yorkshire
    Quote Originally Posted by paul b View Post
    Paul
    The fault here is the plenum chamber - as I found out recently. (A void between the engine bay and the windscreen where the battery sits). There is a drain hole under the battery which can get blocked causing a build up of water.
    OR
    Water ingress from a faulty seal around the pollen filter.
    Both of which cause water to run into the car, behind the carpet in the passenger side footwell.
    Audi have placed an electronic control unit here, under the carpet, which looks after electric windows, alarm, centrtal locking, etc. If this gets wet, you may condsider hiring an exorcist as all sots of strange things start to happen.
    2007 Audi A6 3.0 TDi quattro S line manual saloon
    1975 Rover P6 4000S 5 speed
    Time flies like an arrow
    Fruit flies like a banana
  5. Re: Alarm fault on a6
    thanks for the info lads..but i,ll book a exorcist aswell. well if he cant fix my car then maybe he could render fults with my wife and kids lol..
  6. Re: Alarm fault on a6
    You can get a fault read out and it can pinpoint what has activated the alarm
  7. Re: Alarm fault on a6
    Aug 2007
    Wiltshire, UK
    Similar kind of thing started on mine- but only in the cold. The alarm started sounding in cold weather overnight around Christmas. Whenever I checked all seemed OK. After reading the advice on these forums I changed my main battery - it had run flat once recently so no probs.
    Then over this last weekend the temperature dropped to -2C in the campsite I was sleeping at in the Lakes and the damn thing went off again. I wasn't too popular there! Had to leave the car unlocked all night.
    I just spoke to Swindon Audi who said that the problem wasn't likely to be the battery backup in the siren because if that battery had issues it would sound the (beep beep) siren but not flash the hazards. My hazards are flashing when it goes off.
    I plugged my shareware version of VAGCOM into it yesterday and it said alarm triggered twice - once by front left door and once by rear right door. Swindon Audi said this didn't sound right and was there water near the convenience unit? There isn't - I'm aware of that one.
    Their advice was to either let it develop, give it them anyway ((watch the weather forcast for cold weather ??) not happy to do at 75 quid plus VAT an hour) or to use VAGCOM to tell the car there is no alarm.
    Any thoughts ?
  8. Re: Alarm fault on a6
    Hi You know what has activated the alarm,which is an advantage.There is possibily water in the door locks.Look on the bright side though,i think we have waved goodbye to the minus degrees,(for the time being)
  9. Re: Alarm fault on a6
    Aug 2007
    Wiltshire, UK
    Hey Kenney,
    I hope you're right about the goodbyes but it just puts the problem off by 6 months, until autumn comes round again. Wouldn't water cause problems whether it was cold or not ? Was dry as a bone on saturday when it went of that evening ...
  10. Re: Alarm fault on a6
    There are 4 micro switches in the door lock,the only explanation i can give you is,water expands,when it freezes,causing one of the switches to make a contact.
  1. alarm
    By blakey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2007, 12:42 PM
  2. MK4 Central Locking and Alarm fault
    By richjthorpe in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2007, 01:34 PM
  3. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  4. ALARM LED
    By BLACKOPS in forum Audi A4 - Archive Topics
    Last Post: 22-11-2006, 03:47 PM
  5. Passat Car Alarm Fault
    By saucebury in forum Passat - Archive Topics
    Last Post: 06-08-2006, 03:21 PM
