Thread: I'm not bleeping?
  1. I'm not bleeping?
    Feb 2019
    Bexhill, England
    My warning bleeper that warns me if I've left the lights on when I get out of the car isn't working and I've already left the lights on a couple of times.
    I've no idea where to start looking to resolve this problem.
  2. Re: I'm not bleeping?
    Apr 2018
    N.Ireland
    9 Post(s)
    Sounds like your car isn't registering that a door has been opened, do you see on the display that doors are open? central locking work on every door? Also a scan might help with the diagnosis.
  3. Re: I'm not bleeping?
    Feb 2019
    Bexhill, England
    The door open warning does show on the display. There has been a problem with the central locking (before I got the car) and the tailgate has to be opened with a key. However, the BLEEP has worked since I've had the car so something else must have gone wrong?
    I am debating getting a CPU scanner as there are always problems with old cars but I'm not sure if they are worth my money or which one to get (different units seem to have different features).
    My local garage charges £10 to scan the CPU - EDIT: plug the fault reader in.
  4. Re: I'm not bleeping?
    Southern County Softy
    20 Post(s)
    The buzzer is in the dash and is known to fail.
    You can remove the dashpod and solder in a new buzzer
    A4 2.5 tdi QS (mapped)
  5. Re: I'm not bleeping?
    Mar 2008
    High Wycombe
    Check if the car is realising the door is open. Does the interior light come on as it should when you open the door? If you have a DIS, does it show the door open symbol?
    You can use VCDS / Vagcom to tell you if the car know the door is open.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Why does my A4 keep bleeping !
    By ihs61 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-03-2010, 07:43 PM
  2. Random bleeping noise on my A6 - Can you help?
    By liveforever in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-01-2010, 11:45 AM
  3. Please Help bleeping
    By age69 in forum Audi A3 - Archive Topics
    Last Post: 30-05-2008, 09:25 AM
  4. mk3 golf cl 1.8 BLEEPING NOISE
    By golf3 in forum Golf MK3 - 1993 - 1999
    Last Post: 13-12-2007, 06:48 PM
  5. Bleeping start-up
    By exile in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-07-2007, 09:18 PM
