Thread: 2.0tdi cr fuel filter
  1. 2.0tdi cr fuel filter
    Oct 2018
    Bishop Auckland
    Does anybody know how change this filter. I've done a few with the torx screws but this one is a bit different do I need vagcom or can I just pre fill with fuel tia
  2. Re: 2.0tdi cr fuel filter
    1840 Post(s)
    You MUST bleed the system afterwards by running the in tank and (if fitted) high pressure electric pump next to the cam cover, if you don't there is a high possibility of damage to the mechanical high pressure fuel pump which is daft money to replace.
  3. Re: 2.0tdi cr fuel filter
    Oct 2018
    Bishop Auckland
    okay cheers I'll just get the garage to do it
  4. Re: 2.0tdi cr fuel filter
    1840 Post(s)
    Make sure they do, many don't know/can't/care/agree
  1. Should fuel filter/pollen filter be included as part of service?
    By jasonvaughan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-11-2018, 08:33 PM
  2. Solved Whats the correct way to bleed up a 3.0tdi after fuel filter change?
    By lynalldiscovery in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-01-2017, 02:28 PM
  3. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  4. DIY fuel filter change on 3.0tdi Quattro
    By Damien82uk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-04-2013, 10:25 AM
  5. Replies: 0
    Last Post: 10-02-2010, 01:39 PM
