Thread: Avant rear wiper (again!!!)
  1. Avant rear wiper (again!!!)
    Feb 2019
    Bristol
    Hi everyone. This appears to be a common issue but its doing my nut in! I have a 2008 Avant 1.9TDi. The rear wiper was playing up. Not coming and such. So I took it all to bits as it was seized up. The tube had corroded in the unit water in (not the best design!) Anyway, took it all to bits, cleaned it up shiny new, put a little grease back on the gears and put it back together. Plugged it back in a whey hey working wiper! Trouble is now it won't switch off!!! No matter the position of the stork its is constantly on intermittent. So now as a result I have had to unplug it at the motor. Has anyone else had this problem? I see a few folk have issues with this wiper and a good clean out does the trick! Alas not for me!! haha!!
    Matty
  2. Re: Avant rear wiper (again!!!)
    131 Post(s)
    1974 Post(s)
    Common isn’t the word, look at any A3 type 8P or A4/6 avant and almost invariably the rear wiper motor will be faulty
  3. Re: Avant rear wiper (again!!!)
    May 2012
    Everywhere
    308 Post(s)
    That's what happens when you let a French manufacturer put bits on a German car .
    1 1 0
  4. Re: Avant rear wiper (again!!!)
    131 Post(s)
    1974 Post(s)
    The first big recal of VW’s I was ever involved with was the Golf 2 heater matrix bursting problem, a part made by...... Valeo...
    1 1 0
  5. Re: Avant rear wiper (again!!!)
    Apr 2018
    Waddingham
    I had this same problem, water gets in to the small circuit board located on the outside of the casing near where it plugs in to the connector. I opened that up and board was all corroded so cleaned up put back together and covered in vaseline to try and stop water/moisture getting back in. Was fine for about a month then went again, had a mind of it's own. Ended up buying unbranded new replacement from auction site... problem sorted, for now anyhow
  1. a6 avant rear wiper
    By boidy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-01-2014, 02:29 PM
  2. Avant rear wiper arm too low
    By AudiCraig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2013, 01:59 PM
  3. Avant Rear Wiper
    By p1lts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-11-2010, 05:23 PM
  4. Avant rear wiper again.
    By vma99r in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-01-2010, 04:18 PM
  5. Avant Rear Wiper
    By Cpt Shed in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2009, 10:20 AM
