Thread: RCD510 bluetooth...
  1. RCD510 bluetooth...
    Apr 2013
    Welwyn Garden City / Milton Keynes
    I have got a 2007 (57 plate) Caddy 2K.
    I currently have a RCD300 headunit fitted, with a horrible aftermarket nokia handsfree bluetooth system.
    I would like to replace this tired looking headunit with something more modern, like a RCD310 or RCD510.
    I have done some research, and understand I will need to change to a later CAN Gateway to avoid the well known battery drain issues.
    I believe that neither the RCD310 or RCD510 have inbuilt bluetooth like the RNS315, but I am not bothered about OEM sat nav.
    My question is, if I retrofit an RCD510 headunit with a newer CAN Gateway and VW bluetooth module, how will I control the phone without steering wheel buttons? I know there is a "Phone" button on the RCD510, but I don't know what functionality I would have without buttons on the steering wheel?
    Any help appreciated,
    Rich
  2. Re: RCD510 bluetooth...
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Not sure if it will help you, but when I got a Bluetooth module to add to the RNS510 in our newer VW I had a quick experiment to see if it worked with the RCD300 in the 53 plate Touran. This was what I found out: Modern Bluetooth module, old car, no MFSW / radio control: it works!!
    So you could get the module and try it with the RCD300. If you can control the actual handset via a spare finger or voice you may not need an RCD upgrade.
  1. RCD510 + Bluetooth
    By tec1 in forum Golf MK6 - 2009 - 2013
    Last Post: 25-08-2014, 12:49 PM
  2. Review of Premium Bluetooth and RCD510
    By Teflon in forum In Car Entertainment
    Last Post: 01-08-2013, 06:08 PM
  3. Add Bluetooth to RCD510
    By anand81uk in forum Golf MK6 - 2009 - 2013
    Last Post: 17-08-2009, 02:37 PM
  4. Question Rcd510
    By wacits in forum In Car Entertainment
    Last Post: 14-04-2009, 11:53 PM
  5. Where to get a RCD510 from?
    By dan_the_v8man in forum In Car Entertainment
    Last Post: 28-02-2009, 12:07 PM
