Thread: Passat not starting!
Results 1 to 10 of 11
  1. Passat not starting!
    Oct 2009
    ireland
    Passat 1.6 tdi. Car will not start or crank over and displays "engage clutch" message. It will start no problem if bumped. There are no fault codes. The sensor/ switch at top of clutch pedal was replaced but no different. Mechanic has not seen this problem before. Has anyone any ideas?? Thanks.
  2. Re: Passat not starting!
    Oct 2009
    ireland
    Should say 2013 car.
  3. Re: Passat not starting!
    131 Post(s)
    1978 Post(s)
    The clutch position sensor is on the master cylinder in the engine bay and it’s design was changed on the 12/10/14 due to reliability problems, which part number switch did he fit?
  4. Re: Passat not starting!
    Oct 2009
    ireland
    Sorry my mistake. It is fitted at master cylinder. I don't know part no but a new one was fitted and the car started for several days but then went back to not starting. At the same time this was fitted the dash started to display handbrake fault(orange light).
    Mechanic has nowreplaced master cylinder and h/brake light is off but car still not starting. Still no fault codes.
  5. Re: Passat not starting!
    131 Post(s)
    1978 Post(s)
    He needs to check the live data to the start authorisation to see if it is showing the pedal is depressed.
  6. Re: Passat not starting!
    Oct 2009
    ireland
    I take it the mechanic will need vagcom? His diagnostics is snap on.
  7. Re: Passat not starting!
    Oct 2009
    ireland
    Just to update this for future readers..car hooked up to vagcom and no problems showing. According to the laptop the car is behaving as normal even though it doesn't start. So in the end the mechanic connected a starter button to starter and placed into the dash.
  8. Re: Passat not starting!
    131 Post(s)
    1978 Post(s)
    That is what we tend to call a bodge....
  9. Re: Passat not starting!
    Jan 2016
    Winchester Hants
    29 Post(s)
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 68K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  10. Re: Passat not starting!
    Oct 2009
    ireland
    Yip a bodge alright but it works every time so my papa is a happy man. Cars getting sold next month anyway, new one coming. He didn't want to throw any more money at this one.
  1. Passat 2.0 BKD not starting
    By diag1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-07-2015, 01:17 AM
  2. Passat B6 Non starting
    By nashyn in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2015, 08:41 AM
  3. Passat not starting
    By Berkshire_Boy76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-08-2010, 07:58 AM
  4. 99 Passat TDI Smoky on Starting
    By chrisevans69 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-12-2007, 02:50 PM
  5. passat not starting
    By Brainscram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 11:42 AM
