Thread: P2563 error code, flashing coil light, low oil pressure warning and red oil light on
  1. Exclamation P2563 error code, flashing coil light, low oil pressure warning and red oil light on
    Feb 2019
    Ash
    Hi All, hoping someone on here can help me out.
    I have the error code 09571 P2563 - on my 59 plate VW golf gtd.
    this has now put my car into limp mode, wont go over 2.5K revs and i have oil pressure warning and the dreaded red oil light telling me to stop driving immediately!
    I have flushed the engine to remove any blockage or thick old oil, drained it, changed the filter and put brand new oil in - still have same problem.
    I had new actuator fitted over a year ago and no problems during last year so not sure its that.
    I have no idea where to go with it next - have been reading all the threads on crankshaft sensors or Lambda errors!
    some sort of oil pressure sensor?
    it just stopped working over night.
    anyone had similar issues!?
    have been told my turbo is knackered/ veins are stuck but not sure this would cause low oil pressure and red light warning!?
    or more importantly if low oil pressure has caused turbo to seize - but i had no warning lights or even hints of anything wrong with the car!
    many thanks
  2. Re: P2563 error code, flashing coil light, low oil pressure warning and red oil light on
    134 Post(s)
    2007 Post(s)
    This should just be the diaphragm being split, very common. However, before you run it any more you must have a physical oil pressure test done, the system may not be telling the truth due to a wiring fault, but it could be telling the truth.
  1. Please Help P2563 error code, flashing coil light, flashing EML (engine) light
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-07-2022, 09:41 PM
  2. Replies: 2
    Last Post: 29-08-2018, 06:05 PM
  3. Please Help Fuel Pressure Problem - Flashing coil light
    By Beut834 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-02-2017, 07:08 PM
  4. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Last Post: 07-06-2014, 10:02 PM
  5. 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    By BoyceyS4 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-06-2012, 03:20 PM
