Thread: 1.9 tdi bxe electrical help
  1. 1.9 tdi bxe electrical help
    Jan 2016
    uk
    hi looking for a engine wiring diagram also can anyone tell me what volts i should have at the camshaft sensor plug wires 1 2 3 and what number pins they go to at the ecu?
  2. Re: 1.9 tdi bxe electrical help
    Oct 2017
    London
    12 Post(s)
    I don’t have those details but I can tell you the camshaft sensor on the bxe is very prone to total failure. Im not sure if that’s your problem but if it is use vcds to confirm, if you don’t have that a failed sensor will mean the car takes an extra second or so to start
  3. Re: 1.9 tdi bxe electrical help
    Jan 2016
    uk
    thanks for your reply i have changed the sensor and still takes a few seconds to start and have to press accelerator.and is lumpy on tick over.
  4. Re: 1.9 tdi bxe electrical help
    132 Post(s)
    1980 Post(s)
  5. Re: 1.9 tdi bxe electrical help
    Oct 2017
    London
    12 Post(s)
    Quote Originally Posted by tay72dog View Post
    Have you access to any diagnostics to confirm the camshaft sensor is bad or any other problems? Im pretty sure a failed camshaft sensor wouldnt cause the engine to run lumpy although it would cause it to start slower.
  1. Please Help Electrical
    By Bob Holmes in forum A8 - S8 - V8
    Last Post: 02-03-2013, 11:18 AM
  2. electrical help
    By truckerjim in forum Ireland
    Last Post: 06-04-2011, 02:09 PM
  3. Please Help Electrical problem?
    By msa1837 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2010, 09:50 AM
  4. Please Help Electrical Issue, I think?
    By Mxyeow in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2010, 04:41 PM
  5. Mk3 GTI electrical cut out
    By alangolfgti in forum Golf MK3 - 1993 - 1999
    Last Post: 28-04-2009, 09:57 PM
